Set a Project Parameter
62BJW
Message 1 of 8
62BJW
I know how to set a parameter of an element I can select but how do you set a project parameter? Thanks.
Replies (7)
Message 2 of 8
jeremytammik
Please always search the help file, SDK samples, Internet, The Building Coder and especially this forum for existing answers before posting a new question.
Most questions have already been answered multiple times over.
In this case, I searched for 'set project parameter' and saw many related threads, e.g.,:
https://forums.autodesk.com/t5/revit-api-forum/set-a-shared-project-parameter-remains-not-assigned/m...
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 8
62BJW
I have already been through many if not most of the material in that blog.
Message 4 of 8
62BJW
My reply was to this reply I got in an email. "I would suggest you do this right away, before asking any further questions  :-)"
I will look into the possible solution you posted here. Sorry if I've asked too many questions. I'm new to this forum, is there a limit?
Thanks for the help.
Message 5 of 8
62BJW
I structured my question incorrectly. My apologies. I'm actually trying to set the value of a project parameter (created from a shared parameter) that is in the "Project Information" category. I know how to get and set parameters of elements that I can select but there's no object to select (in this case) when it's in the project information category.
Message 6 of 8
62BJW
Document Doc = commandData.Application.ActiveUIDocument.Document;
Parameter myParam = Doc.ProjectInformation.LookupParameter ("Building Designator");
myParam.Set("B");
This works
Message 7 of 8
jeremytammik
Congratulations on solving the issue!
Congratulations also on narrowing down what the real question actually was: setting a (normal) parameter on the project information element.
To answer your other question: nope, there is no limit on the number of questions you can submit here.
On the other hand: yes, certainly, obviously, there are personal limits on the number, complexity, and repetitivity of questions individual forum members feel happy to answer.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 8 of 8
baderalsheibani
Thanks a million!
Simple clean code. I don't why some like to complicate things!!
