Dimension subelement not working
[Revit API , CSharp]
Hi everyone, I hope you will help me!!
My code:
#region Namespaces
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using System;
using System.Collections.Generic;
using System.Diagnostics;
using System.Linq;
#endregion
namespace Question
[Transaction(TransactionMode.Manual)]
public class Command : IExternalCommand
public Document doc { get; set; }
/// <summary>
/// External command mainline
/// </summary>
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
try
// Display WPF Form
// _wpfWindowController.ShowForm(commandData.Application);
doc = commandData.Application.ActiveUIDocument.Document;
DimensionType dimensionType = new FilteredElementCollector(doc).OfClass(typeof(DimensionType)).Cast<DimensionType>().FirstOrDefault();
Grid gridperH = doc.GetElement(new ElementId(419358)) as Grid;
FamilyInstance ins = doc.GetElement(new ElementId(419291)) as FamilyInstance;
XYZ loc = (ins.Location as LocationPoint).Point;
Line line = Line.CreateBound(loc + XYZ.BasisY, loc + XYZ.BasisY + XYZ.BasisX);
// Dimension OK
FamilyInstance insSingle = doc.GetElement(new ElementId(422010)) as FamilyInstance;
ReferenceArray referenceArr = new ReferenceArray();
referenceArr.Append(GetReferenceFromGrid(gridperH));
referenceArr.Append(GetCurveCenterFamilyInstance(insSingle));
DimensionTest(line, referenceArr);
// Dimension Sub Element : Error
referenceArr.Append(GetCurveCenterFamilyInstance(ins));
return Result.Succeeded;
catch (Exception ex)
message = ex.Message;
return Result.Failed;
public void DimensionTest(Line line, ReferenceArray refArr)
using (Transaction tx = new Transaction(doc))
tx.Start(" TransactionName ");
doc.Create.NewDimension(doc.ActiveView, line, refArr);
tx.Commit();
public Reference GetReferenceFromGrid(Grid grid)
Reference reference = null;
Options DefaultOptions = new Options();
DefaultOptions.ComputeReferences = true;
DefaultOptions.IncludeNonVisibleObjects = true;
DefaultOptions.View = doc.ActiveView;
GeometryElement geoElem = grid.get_Geometry(DefaultOptions);
double length = 0;
foreach (var item in geoElem)
Curve curve = item as Curve;
if (curve != null)
if (curve.Length > length)
reference = curve.Reference;
length = curve.Length;
return reference;
public Reference GetCurveCenterFamilyInstance(FamilyInstance faIns)
Options geomOptions = new Options();
geomOptions.ComputeReferences = true;
geomOptions.View = doc.ActiveView;
geomOptions.IncludeNonVisibleObjects = true;
GeometryElement gElement = faIns.get_Geometry(geomOptions);
List<Curve> lstcu = GetCurvesElement(gElement, false);
var curveOrigin = lstcu.Where(k => k.IsBound == true && (k as Line) != null &&
(k.GetEndPoint(0).DistanceTo(new XYZ(0, 0, k.GetEndPoint(0).Z)) <= 0.0001 || k.GetEndPoint(1).DistanceTo(new XYZ(0, 0, k.GetEndPoint(1).Z)) <= 0.0001))
.FirstOrDefault();
return (curveOrigin.GetEndPoint(0).DistanceTo(XYZ.Zero) < curveOrigin.GetEndPoint(1).DistanceTo(XYZ.Zero)) ? curveOrigin.GetEndPointReference(0) : curveOrigin.GetEndPointReference(1);
public List<Curve> GetCurvesElement(GeometryElement geoEle, bool IsGetGeometryInstance = true)
List<Curve> lstcuves = GetCurvesGeoElement(geoEle, IsGetGeometryInstance);
return lstcuves;
private List<Curve> GetCurvesGeoElement(GeometryElement geoEle, bool IsGetGeometryInstance = true)
List<Curve> lstRes = new List<Curve>();
// get references
foreach (var geo in geoEle)
GeometryInstance geoIns = geo as GeometryInstance;
if (geoIns != null)
GeometryElement newGeo = IsGetGeometryInstance == true ? geoIns.GetInstanceGeometry() : geoIns.GetSymbolGeometry();
if (newGeo != null)
List<Curve> lst = GetCurvesGeoElement(newGeo, IsGetGeometryInstance);
if (lst.Count > 0)
lstRes.AddRange(lst);
Curve curve = geo as Curve;
if (curve != null)
lstRes.Add(curve);
return lstRes;
}My problem is as follows:
- (id=422101): If I dim the familyInstance object, it runs normally
- (id=419291): But since I dim familyInstance is a sub element then it doesn't work!
------ family (419291) = Family (422010)
My code + File Revit: https://drive.google.com/drive/folders/1T4-v_WcTcc-8KW3W9CYkU9f6iPdgrcUr?usp=sharing
[If there are examples, the better!!]
Thanks you very much!!!
