Dimension subelement not working
dreamofbaby0507
dreamofbaby0507
[Revit API , CSharp]
Hi everyone, I hope you will help me!!
My code:
#region Namespaces
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using System;
using System.Collections.Generic;
using System.Diagnostics;
using System.Linq;
#endregion
namespace Question
    [Transaction(TransactionMode.Manual)]
    public class Command : IExternalCommand
        public Document doc { get; set; }
        /// <summary>
        /// External command mainline
        /// </summary>
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            try
                // Display WPF Form
                // _wpfWindowController.ShowForm(commandData.Application);
                doc = commandData.Application.ActiveUIDocument.Document;
                DimensionType dimensionType = new FilteredElementCollector(doc).OfClass(typeof(DimensionType)).Cast<DimensionType>().FirstOrDefault();
                Grid gridperH = doc.GetElement(new ElementId(419358)) as Grid;
                FamilyInstance ins = doc.GetElement(new ElementId(419291)) as FamilyInstance;
                XYZ loc = (ins.Location as LocationPoint).Point;
                Line line = Line.CreateBound(loc + XYZ.BasisY, loc + XYZ.BasisY + XYZ.BasisX);
                // Dimension OK
                FamilyInstance insSingle = doc.GetElement(new ElementId(422010)) as FamilyInstance;
                ReferenceArray referenceArr = new ReferenceArray();
                referenceArr.Append(GetReferenceFromGrid(gridperH));
                referenceArr.Append(GetCurveCenterFamilyInstance(insSingle));
                DimensionTest(line, referenceArr);
                // Dimension Sub Element : Error
                referenceArr.Append(GetCurveCenterFamilyInstance(ins));
                return Result.Succeeded;
            catch (Exception ex)
                message = ex.Message;
                return Result.Failed;
        public void DimensionTest(Line line, ReferenceArray refArr)
            using (Transaction tx = new Transaction(doc))
                tx.Start(" TransactionName ");
                doc.Create.NewDimension(doc.ActiveView, line, refArr);
                tx.Commit();
        public Reference GetReferenceFromGrid(Grid grid)
            Reference reference = null;
            Options DefaultOptions = new Options();
            DefaultOptions.ComputeReferences = true;
            DefaultOptions.IncludeNonVisibleObjects = true;
            DefaultOptions.View = doc.ActiveView;
            GeometryElement geoElem = grid.get_Geometry(DefaultOptions);
            double length = 0;
            foreach (var item in geoElem)
                Curve curve = item as Curve;
                if (curve != null)
                    if (curve.Length > length)
                        reference = curve.Reference;
                        length = curve.Length;
            return reference;
        public Reference GetCurveCenterFamilyInstance(FamilyInstance faIns)
            Options geomOptions = new Options();
            geomOptions.ComputeReferences = true;
            geomOptions.View = doc.ActiveView;
            geomOptions.IncludeNonVisibleObjects = true;
            GeometryElement gElement = faIns.get_Geometry(geomOptions);
            List<Curve> lstcu = GetCurvesElement(gElement, false);
            var curveOrigin = lstcu.Where(k => k.IsBound == true && (k as Line) != null &&
            (k.GetEndPoint(0).DistanceTo(new XYZ(0, 0, k.GetEndPoint(0).Z)) <= 0.0001 || k.GetEndPoint(1).DistanceTo(new XYZ(0, 0, k.GetEndPoint(1).Z)) <= 0.0001))
                .FirstOrDefault();
            return (curveOrigin.GetEndPoint(0).DistanceTo(XYZ.Zero) < curveOrigin.GetEndPoint(1).DistanceTo(XYZ.Zero)) ? curveOrigin.GetEndPointReference(0) : curveOrigin.GetEndPointReference(1);
        public List<Curve> GetCurvesElement(GeometryElement geoEle, bool IsGetGeometryInstance = true)
            List<Curve> lstcuves = GetCurvesGeoElement(geoEle, IsGetGeometryInstance);
            return lstcuves;
        private List<Curve> GetCurvesGeoElement(GeometryElement geoEle, bool IsGetGeometryInstance = true)
            List<Curve> lstRes = new List<Curve>();
            // get references
            foreach (var geo in geoEle)
                GeometryInstance geoIns = geo as GeometryInstance;
                if (geoIns != null)
                    GeometryElement newGeo = IsGetGeometryInstance == true ? geoIns.GetInstanceGeometry() : geoIns.GetSymbolGeometry();
                    if (newGeo != null)
                        List<Curve> lst = GetCurvesGeoElement(newGeo, IsGetGeometryInstance);
                        if (lst.Count > 0)
                            lstRes.AddRange(lst);
                Curve curve = geo as Curve;
                if (curve != null)
                    lstRes.Add(curve);
            return lstRes;
My problem is as follows:
 - (id=422101): If I dim the familyInstance object, it runs normally
- (id=419291): But since I dim familyInstance is a sub element  then it doesn't work!
 ------   family (419291) = Family (422010)
My code + File Revit: https://drive.google.com/drive/folders/1T4-v_WcTcc-8KW3W9CYkU9f6iPdgrcUr?usp=sharing
[If there are examples, the better!!]
Thanks you very much!!!
FAIR59
You are trying the place dimensions. Dimensions only work on visible objects. The dimension you created is in the database, but isn't shown because it refers to a non-visible line.
Set the value for [ geomOptions.IncludeNonVisibleObjects ] to false in the  GetCurveCenterFamilyInstance() method, and all should be fine.
dreamofbaby0507
I have done it. Thank you very much!!
