Difference between FamilySymbol and ElementType?
Both FamilySymbol and ElementType seem to represent the same idea.  What is the difference between the two?  (I know one derives from the other)
A related question is: what's the difference between Element and FamilyInstance?  I can't understand why stairs are of class Stairs (derived from Element), while doors are of class FamilyInstance.  Are stairs not an "instance" of a particular "family"?
jeremytammik
Families come in several flavours.
The two main ones are standard and built-in.
Standard are defined in RFA family definitions.
Built-in are built into Revit directly.
Standard families define family symbols, and when you place a family symbol, it is represented by a family instance.
Other elements placed in the model are not called family instances; they are just elements.
Element is a super-class of FamilyInstance.
Analogously, ElementType is a superclass of FamilySymbol.
I hope this explains.
For more info, check the developer guide:
http://help.autodesk.com/view/RVT/2019/ENU/?guid=Revit_API_Revit_API_Developers_Guide_Introduction_E...
Revit Developer's Guide
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Ah, that's very helpful, thank you for the explanation and links!
jeremytammik
Thank you for your appreciation!
Shared for posterity by The Building Coder:
https://thebuildingcoder.typepad.com/blog/2018/12/dynamo-symbol-vs-type-and-exporter-exception.html#...
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
hrasmussen
Jeremy,
If I had to guess, I'd say you've been the guy with the answer to about 80% of my Revit API questions - thanks for all your posts (this one included)!
