Access line weight for dimension lines
ritesh.solankeSKPPH
ritesh.solankeSKPPH
I want to access dimension line's line weight and even end points for the witness lines programmatically.i have attached a screenshot of what exactly I want.
jeremytammik
Before you do anything else whatsoever, install RevitLookup:
https://github.com/jeremytammik/RevitLookup
It is an interactive Revit BIM database exploration tool to view and navigate element properties and relationships.
Use that to discover the relationships between the dimension lines, their styles and the properties you are looking for.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
BardiaJahan
As Jeremy said, RevitLookup is a useful tool to find the relationship between elements. etc.
For the line weight you can get BuiltInParameter.LINE_PEN from the dimension type:
ElementId dimTypeId = dimension.GetTypeId();
Element dimType = document.GetElement(dimTypeId);
Paramater lineWeight = dimType.get_Parameter(BuiltInParameter.LINE_PEN);
