Revit Formula for Visibility & Text
I have created a cabinet family, in which I have got lock & different set of handles. Each handles has got variant name & it has been created as instance parameter. Now that, I need to create a parameter of combination of both visibility & text. Ex: If lock is made visible in the project, it should display "K", if 3rd type of handle is made visible , it should display "R". Kindly let me know
jeremytammik
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
If you are doing it programmatically, please be aware that the Revit API hardly ever supports any functionality that is not also available in the user interface.
Therefore, if the UI does not support this, the API will probably not do so either.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
