04:23 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
*This post was originally posted on the wrong forum*
I am attempting to start developing addins for Revit 2014 but I can't seem to get past the basics; my addin isn't appearing and no error messages are being displayed, etc.
I am following this tutorial here: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=16849339
But the addin isn't appearing.
I have the addin file located in the %AppData%\Roaming\Autodesk\Revit\Addins\2014folder with the following contents:
<?xml version="1.0" encoding="utf-8"?> <RevitAddIns> <AddIn Type="Command"> <Assembly> C:\Users\[[My Account]]\Documents\Visual Studio 2013\Projects\Lab1PlaceGroup\Lab1PlaceGroup\bin\Release\Lab1PlaceGroup.dll </Assembly> <ClientId>502fe383-2648-4e98-adf8-5e6047f9dc34</ClientId> <FullClassName>Lab1PlaceGroup</FullClassName> <Text>Lab1PlaceGroup</Text> <VendorId>ADSK</VendorId> <VisibilityMode>AlwaysVisible</VisibilityMode> </AddIn> </RevitAddIns>
What else do I need to do to get an addin to display?
Is there also a way to enable debugging or output of errors to a file so that I can see if the addin failed to load for some reason?
Thank you.
