export a schedule
export a schedule
export a schedule
Hi!
I want to export schedules to excel. User opens a schedule, clicks the button and saves this schedule to a specified folder.
I use following code:
      FilteredElementCollector col  = new FilteredElementCollector( doc ).OfClass( typeof( ViewSchedule ) );
      ViewScheduleExportOptions opt = new ViewScheduleExportOptions();
      SaveFileDialog saveFileDialog1 = new SaveFileDialog();
      saveFileDialog1.Filter = "Excel file(*.xls)|*.xls|CSV file(*.csv)|*.csv|Text file(*.txt)|*.txt";
      saveFileDialog1.FilterIndex = 1;
      saveFileDialog1.RestoreDirectory = true;
              foreach (ViewSchedule vs in col)
                  string path, filename;
                  Autodesk.Revit.DB.View view = uidoc.ActiveView;
                  if (view.ViewType == ViewType.Schedule)
                      saveFileDialog1.ShowDialog();
                      path = Path.GetDirectoryName(saveFileDialog1.FileName);
                      filename = uidoc.ActiveView.Name;
                      if (saveFileDialog1.FileName != "")
                          vs.Export(path, vs.Name + _ext, opt);
                          return Result.Succeeded;
                  else
                      filename = "Choose schedule an active view";
                      TaskDialog.Show("Active view is", filename);
                      return Result.Failed;
There is one mistake. I use foreach, so it returns and saves first schedule in my project.
But I need to save the schedule that is in active view.
How can I acheive this?
Alexander.
FilteredElementCollector collector = new FilteredElementCollector(doc, doc.ActiveView.Id).OfClass(typeof(ViewSchedule));;
Remy, thank you for your valuable answer.
Unfortunatelly revit doesn't return anything when I enter doc.ActiveView.Id , I cheked it within debugger. The same result occurs when I used BuiltInCategory.
Alexander
this is very strange, are you sure you have selected a view ? Because the project browser is also considered as a view.
arnostlobel
That is strange indeed that ActiveDocument would return a null. There have been some changes over the years in implementation of UIDocument.ActiveView, but I believe we have kept it backward compatible. That means the property (at least the one on UIDocument – which is, by the way, the only right object to get an active view from) should return a valid view regardless of whether the view is graphic (e.g. a Sheet) or non-graphic (e.g. the Browser). Naturally, this only applies to Revit versions where non-graphic views were publicly available (i.e. obtainable via the API); I do not think it was the original way though (like in 2012 and maybe even 2013, I do not recall that detail).
The sum it up, In the current version of Revit, UIDocument.ActiveView should return a valid instance of View regardles of the type o fth view, unless the document itself is not the active one in Revit. Naturally, the active view can be only had on the current active document.
Note: I recall a fix being made correcting the way Revit would see dockable views. Before the fix was made such views might mess with the ActiveView property. I believe we made that a hot fix in one of 2014 updates.
Arnošt Löbel
Autodesk, Revit R&D
Arnošt Löbel
I have selected walls like in Revit API sample:
private void CountElements(Autodesk.Revit.DB.Document document)
    StringBuilder message = new StringBuilder();
    FilteredElementCollector viewCollector =
        new FilteredElementCollector(document, document.ActiveView.Id);
    viewCollector.OfCategory(BuiltInCategory.OST_Walls);
    message.AppendLine("Wall category elements within active View: "
       + viewCollector.ToElementIds().Count);
    FilteredElementCollector docCollector = new FilteredElementCollector(document);
    docCollector.OfCategory(BuiltInCategory.OST_Walls);
    message.AppendLine("Wall category elements within document: "
       + docCollector.ToElementIds().Count);
    TaskDialog.Show("Revit", message.ToString());
 And in this case program works without problems. ActiveView returned valid value.
Alexander.
Can you take your code in this totality ?
Thanks.
Xavier.
