Design automation issue with activityId not found
ryan_chesnut
ryan_chesnut
Following the steps to create a work item in design automation. Step 7 gives this error.
Can someone confirm what the activity id should look like?
“activityId”: [
        “The activity Concora_App_1.concoraActivity2+testAppBundleId3 could not be found (Parameter ‘activityId’)”
This is the payload we are sending.
        "activityId": "Concora_App_1.concoraActivity2+testAppBundleAlias2",
        "arguments": {
          "rvtFile": {
            "url": "urn:adsk.objects:os.object:concorabucket11/DeleteWalls1",
              "verb": "get",
              "headers": {
                  "Authorization": "Bearer {{accessToken}}"
          "result": {
            "url": "urn:adsk.objects:os.object:concorabucket11/DeleteWallsResult",
            "verb": "put",
              "headers": {
ricaun
Usually, issues about Forge/APS are not dealt with in this forum, I suppose the official is the StackOverflow.
But I believe in your case you need to send the ActivityId alias.
Try Concora_App_1.concoraActivity2+testAppBundleAlias2.
The error shows that you are sending Concora_App_1.concoraActivity2+testAppBundleId3 as the ActivityId, probably does not exist.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
