Multithreaded parameter reading in ReadOnly
ankofl
ankofl
@jeremytammik
Everyone knows that the application of transactions is available only in one thread, but what about reading the parameters of an element from several threads?
Reading the geometry of an object from several streams into a string works fine (and it gives a multiple increase in execution speed), but if you get at least a list of parameters, not to mention reading them,
// in 121-124 line
else
    var param = elem.Parameters;
the revit simply closes even without an error report.
namespace Client.Main
	[Transaction(TransactionMode.Manual)]
	public class MultiThread : IExternalCommand
		public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
			Thread.CurrentThread.CurrentCulture = new CultureInfo("en-US");
			Document Doc = commandData.Application.ActiveUIDocument.Document;
			string data = "";
			try
				Stopwatch timer = new Stopwatch();
				int threadCount = 5;
				var list = new FilteredElementCollector(Doc).OfClass(typeof(Wall)).WhereElementIsNotElementType().ToList();
				for (int i = 0; i < 10; i++)
					list.AddRange(new FilteredElementCollector(Doc).OfClass(typeof(Wall)));
				List<string> listResult = new List<string>();
				timer.Start();
				listResult = GetData(list);
				timer.Stop();
				data += $"Синхронно {timer.ElapsedMilliseconds}мс\t Count:{listResult.Count}\n";
				if (DivideList(list, threadCount, out List<List<Element>> listOut))
					timer.Reset();
					timer.Start();
					List<Task<List<string>>> listTask = new List<Task<List<string>>>();
					for (int i = 0; i < listOut.Count; i++)
						var listCur = listOut[i];
						var task = Task.Run(() => GetIdAsync(listCur));
						listTask.Add(task);
					Task.WaitAll(listTask.ToArray());
					foreach (var task in listTask)
						List<string> ids = task.Result;
						listResult.AddRange(ids);
					timer.Stop();
					data += $"Многопоточно {timer.ElapsedMilliseconds}мс\t Count:{listResult.Count}\n";
					timer.Reset();
					timer.Start();
					List<string>[] array = new List<string>[listOut.Count];
					Parallel.For(0, listOut.Count, x =>
						var listCur = listOut[x];
						var dataParallel = GetData(listCur);
						array[x] = dataParallel;
					for (int i = 0; i < array.Length; i++)
						listResult.AddRange(array[i]);
					timer.Stop();
					data += $"Параллельно {timer.ElapsedMilliseconds}мс\t Count:{listResult.Count}\n";
			catch (Exception e)
				data = e.Message;
			TaskDialog.Show("Result", data);
			return Result.Succeeded;
		public static List<string> GetData(List<Element> listElem)
			List<string> listData = new List<string>();
			foreach (var elem in listElem)
				if (true)
					var geom = elem.get_Geometry(new Options()); //.get_Parameter(BuiltInParameter.ALL_MODEL_INSTANCE_COMMENTS);
					foreach (var geoElem in geom)
						if (geoElem is Solid solid)
							foreach (Face face in solid.Faces)
								if (face is PlanarFace pFace)
									Mesh mesh = pFace.Triangulate();
									for (int i = 0; i < mesh.NumTriangles; i++)
										var tri = mesh.get_Triangle(i);
										XYZ a = tri.get_Vertex(0);
										XYZ b = tri.get_Vertex(1);
										XYZ c = tri.get_Vertex(2);
										listData.Add($"{a.X:f4} {a.Y:f4} {a.Z:f4} {b.X:f4} {b.Y:f4} {b.Z:f4} {c.X:f4} {c.Y:f4} {c.Z:f4} ");
				else
			return listData;
		public static async Task<List<string>> GetIdAsync(List<Element> listElem)
			return GetData(listElem);
		public static bool DivideList(List<Element> listElem, int coountList, out List<List<Element>> listOut)
			listOut = null;
			if (listElem == null || coountList <= 0 || listElem.Count < coountList)
				return false;
			int chunkSize = (int)Math.Ceiling((double)listElem.Count / coountList);
			listOut = Enumerable.Range(0, coountList).Select(i => listElem.Skip(i * chunkSize).Take(chunkSize).ToList()).ToList();
			return true;
If this is a known issue, can someone check if it is fixed in Revit 2025?
jeremy_tammik
All use of the Revit API must be made in the one and only main thread provided by a valid Revit API context.
We have seen examples of multi-threaded operations working, sometimes, temporarily, for a while. Such multi-thread operations can also catastrophically corrupt the model and destroy the BIM.
It may be tempting to use multi-threaded read-only access. In some cases, the Revit API actively tries to prevent it. From the official point of view of the Revit API developers, it is completely forbidden.
ankofl
Thanks for the prompt response!
