Deserialize ElementId: Unable to find a constructor to use for type Autodesk.Revit.DB.ElementId
MiguelGT17
MiguelGT17
Hi folks,
I have this class and it's throwing the following exception when deserializing a json:MiguelGT17_0-1699510533620.png
public class RevitItem{
       public string instanceName { get; set; }
        private List<ElementId> _location;
        public List<ElementId> location //list of ids, because there can be rooms with same name! or using same words
            get { return _location; }
            set { _location = value; }
public RevitItem(string instanceNAME, List<ElementId> roomLoc = null,
            this.instanceName = instanceNAME;
            this.location = roomLoc == null ? new List<ElementId>() :roomLoc;
[JsonConstructor]
        public RevitItem(string instanceNAME, List<dynamic> roomLoc = null,
            this.location = roomLoc == null ? new List<ElementId>() : roomLoc.Select(x=>new ElementId(x.IntegerValue)).ToList();
When I did the serialization, It seems that the List<elementId> location props turns into this object:
any Ideas on how to process this data and turn it into List<ElementId>?
thanks in advance
jeremy_tammik
Yes, sure, lots. Look at the list of ElementId constructors:
  • Constructors:
  • ElementId(Int32) Obsolete.
  • ElementId(Int64)
  • ElementId(BuiltInCategory)
  • ElementId(BuiltInParameter)
Do you see a constructor taking an integer argument?  I don't. So, implement one yourself as an extension method for the ElementId class and call the Int64 native constructor from that. If that does not work, implement an own replacement class for ElementId and figure out how to convert it after deserialisation. Or, or, or.... many paths lead to Rome.
RPTHOMAS108
Storing ElementIds outside of Revit is a dubious process due to changes that occur to such during work-sharing etc. UniqueId or IFCguid is a better option but again I hear that depending on what operations you do in Revit those may change also.
Perhaps some form of spatial id incorporating category is the best option.
