Delete unused views (Views not placed on sheets)
SanjivKapila
Message 1 of 12
SanjivKapila
I'm trying to delete unused views with following conditions: 1. View should not have any dependent views 2. Views which can be placed on multiple sheets (eg Legends) should not be deleted if they are placed on at least one sheet. 3. Unused ViewSchedules should also get deleted Attached code is an unsuccessful attempt at achieving this.
Replies (11)
Message 2 of 12
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @SanjivKapila ,
try using the below link
https://thebuildingcoder.typepad.com/blog/2017/11/purge-and-detecting-an-empty-view.html#2
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Message 3 of 12
SanjivKapila
Hi Naveen
Thanks for your reply, but I'm not trying to detect empty views, rather I'm trying to delete unused views without harming any sheet. Any view placed on the sheet should not be deleted. The issues I'm facing are: dependent views get deleted if we delete the parent view, i'm using the CanBePlacedOnSheet method: but it deletes legends and other views which can be placed on multiple sheets..
Is there a way to collect all the views on the sheets and subtract it from the main collection of views and delete the resulting collection by applying some conditions..
Message 4 of 12
jeremytammik
Yes, you can easily achieve that.
Look at GetAllPlacedViews:
https://www.revitapidocs.com/2020/816db942-4e9c-7278-7f59-53048becc46a.htm
Create a list of all placed view by asking all sheets for their placed views.
Any view that is not contained in that list is unplaced.
Jeremy Tammik
The Building Coder
Message 5 of 12
SanjivKapila
Not Sure Why, but i end up deleting all the legend views even though some are placed on the sheets.
Message 6 of 12
Sean_Page
Check the ViewType property and make sure it does not equal Legend.
if(view.ViewType != ViewType.Legend)
    Add to list
You can also check to see if the BIP VIEWPORT_DETAIL_NUMBER and/or VIEWPORT_SHEET_NUMBER are empty.
Also you may want to look for View Templates as well.
if(!view.IsTemplate)
    Add to list
And a big one I ran into is making sure  not to delete the Patent of any dependent views because typically they are not on sheets.
if(view.GetPrimaryViewId == ElementId.InvalidElementId)
    Add to list
else
    Remove from list
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
Message 7 of 12
Jerry.Vanek.SG
There's a great plug-in from Ideate called SheetManager, which lets you isolate unplaced views.
Message 8 of 12
tylerVD3L4
Can you share the solution and where I would input the code in Revit?
Message 9 of 12
tylerVD3L4
I found a tool that does this. Use pyrevit plugin, and use the Wipe tool
Message 10 of 12
trevor.ritchieC68GZ
Can you just use the "Browser Organisation":
Message 11 of 12
mark.perryS7U4L
Does it smartly hide parent views that aren't on sheets?
Message 12 of 12
archcad2019
Community Visitor
Community Visitor
how i can use this option in revit ? please provide me with steps
