Curves
Curves
riyo1111111
Curves
riyo1111111
Hello everyone.
I have a question please.. can we create a 3d nurbspline ? Because when i give more then 3 points for the controls points. An error show up « Curve must be on plane » .. i read lot of articles here .. really im stuck
even i made a 3d curve in family revit and i load it to doc project but when i select it , i cant deal with it like a CurveElement..
please i appreciate your answers
I know the class "NurbSpline" is derived from the class "Curve". Maybe the methods in this class are helpful to you. You can find it in the RevtiAPI documentation。
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @riyo1111111 ,
try using this below link
https://forums.autodesk.com/t5/revit-api-forum/create-3d-model-curve-from-list-lt-xyz-gt-in-project-...
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
riyo1111111
thanks for answring
it's a solution to make a 3D Curve by DirectShape but we cant deal with it like a ElementCurve.
