Limit the number of tesselated Points
revitaddins
revitaddins
Hi Guys,
Any guidance on how to limit the number of tessellated points? say if curve length is 10, just make 5 points.
CurveArray curves = sketch.Profile.get_Item(0);
                        IList<XYZ> points = new List<XYZ>();
                        if (null != curves)
                            foreach (Curve cur in curves)
                                if(cur.GetType() == typeof(Line))
                                    points.Add(cur.GetEndPoint(0));
                                if (cur.GetType() == typeof(Arc))
                                    points = cur.Tessellate() as List<XYZ>;
                            foreach (XYZ xYZ in points)
                            //Do something with Points
 Currently it's just creating random number of points
Thank you.
cwaluga
The number is certainly not random but rather based on an approximation criterion, curvature or the like. You can take the curve and evaluate it yourself by your own rules if you are not satisfied with the results of tesselate.
