Create 3D model curve from List<XYZ> in project document
Message 1 of 13
Hi everyone,
I need to create a smooth curve that goes through some points defined by List<XYZ>. These points are not in the same plane. I can create the curve in the family document using CurveByPoints like the following:
curveByPts = document.FamilyCreate.NewCurveByPoints(refPtsAr);
However, it does not seem there is a corresponding method for the project document. How can I create a 3D model curve in the project document?
Replies (12)
Message 2 of 13
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Is it possible via Revit UI?
because in Revit UI if it is possible then through Revit API you can achieve this functionality.
From my understanding, I think you can't extrude list of model curves in the project document.
However, You can use the model-in-place command but this command also opens the Revit family editor to create the extrusion.
I hope this helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Message 3 of 13
Revitalizer
what about
ModelCurve mc = doc.Create.NewModelCurve(HermiteSpline.Create(points, false), sketchPlane);
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 4 of 13
Hi Revitalizer,
Thanks for your suggestions. But it still needs a Sketch Plane. In my case the points or the curve is not in a plane.
Message 5 of 13
Hi Naveen,
Thanks for your suggestions. I will try to create the curve in a family document and then import it into a project document.
Message 6 of 13
Revitalizer
just define a new SketchPlane, on any Plane.
Since the Spline is 3D, none of the points need to reside in that Plane.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 7 of 13
Hi Revitalizer,
Thanks. I tried the method by defining an arbitrary plane and got an exception “Curve must be in the plane”
Message 8 of 13
Revitalizer
the solution is not to create a HermiteSpline but a NurbSpline:
https://forums.autodesk.com/t5/revit-api-forum/how-to-draw-modelnurbspline/m-p/7500615
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 9 of 13
But a NurbSpline must lie in a plane.
Message 10 of 13
Revitalizer
okay, okay.
I really think there is no need for creating a Family and placing that into the project just for drawing a 3D curve.
WireframeBuilder builder = new WireframeBuilder();
List<XYZ> points = new List<XYZ>();
points.Add(new XYZ(0, 0, 0));
points.Add(new XYZ(10, 0, 0));
points.Add(new XYZ(10, 10, 0));
points.Add(new XYZ(0, 10, 0));
points.Add(new XYZ(0, 0, 5));
points.Add(new XYZ(10, 0, 5));
points.Add(new XYZ(10, 10, 5));
points.Add(new XYZ(0, 10, 5));
points.Add(new XYZ(0, 0, 10));
points.Add(new XYZ(10, 0, 10));
points.Add(new XYZ(10, 10, 10));
points.Add(new XYZ(0, 10, 10));
builder.AddCurve(HermiteSpline.Create(points, false));
ElementId categoryId = new ElementId(BuiltInCategory.OST_GenericModel);
DirectShape ds = DirectShape.CreateElement(doc, categoryId);
ds.SetShape(builder);
ds.Name = "Helix";
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 11 of 13
Hi Revitalizer,
It works great. Thanks.
Message 12 of 13
how exactly can this be used? Is it possible to simply make this into a button that, for example, takes a formatted .txt file of coordinate and make a 3d model curve in the project?
Message 13 of 13
Revitalizer
please use something like this:
https://thebuildingcoder.typepad.com/blog/2013/10/text-file-driven-automatic-placement-of-family-ins...
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
