Section - Far Clip Offset
Is there a way to have the Far Clip Offset show on Sheets? We have Coordination Sheets and I want to be able to show exactly how far the section is cutting.
Moustafa_K
if it is not possible via UI then it is not Possible via API. but a work round that is to create lines and linked to section ID via IUpdater. so when ever the section changes, you can track that and the far line gets updated.
I hope this helps.
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
