Creating extrusion - unexpected internal error: Code 1
isc01
isc01
Hello
I got a Problem while creating an extrusion. First sample is working, second not.
Working:
oCurves = oApp.NewCurveArray()
oArrCurves = oApp.NewCurveArrArray
oCurves.Append(Line.CreateBound(New XYZ(dRadius, 0, 0), New XYZ(0, 0, 0)))
oCurves.Append(Line.CreateBound(New XYZ(0, 0, 0), New XYZ(0, -dRadius, 0)))
oCurves.Append(Arc.Create(New XYZ(0, 0, 0), dRadius, DegreeToRadiant(270), DegreeToRadiant(360), New XYZ(1, 0, 0), New XYZ(0, 1, 0)))
oArrCurves.Append(oCurves)
oExtrusion = moActFamily.NewExtrusion(True, oArrCurves, mosketchPlane__2, dHeight)
Not working: - Exits with "unexpected internal error: Code 1"
oCurves.Append(Line.CreateBound(New XYZ(0, 0, 0), New XYZ(dRadius, 0, 0)))
oCurves.Append(Line.CreateBound(New XYZ(0, 0, 0), New XYZ(0, dRadius, 0)))
oCurves.Append(Arc.Create(New XYZ(0, 0, 0), dRadius, DegreeToRadiant(0), DegreeToRadiant(90), New XYZ(0, 1, 0), New XYZ(1, 0, 0)))
Dim oDetCurve As ModelCurve = Nothing
oExtrusion = moActFamily.NewExtrusion(True, oDoor, mosketchPlane__2, dHeight)
What am I doing wrong??
aignatovich
Hi!
I think, the reason is that your second curveloop is not continuous
isc01
Hi
Not sure:
Looking at the 2D I can't see, why I am not able to create a Extrusion out of example 2. Example 1 is no Problem. If i draw the lines of example 2 via the api and than create the Extrusion manually in revit it works.:
Img 1 = Lines example 1
Img 2 = Extrusion example 1
Img 3 = lines example 2
aignatovich
Hi!
The end of the first line in the curveloop should be the beginning of the second line, the end of second line in the curveloop should be the beginning of the third line in the curveloop and so on.
This rule is broken in the second example
