Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Creating an offset walll
2 REPLIES 2
Bruno_Neves_Pires_Silva
1211 Views, 2 Replies
  I am trying to create an offset wall, trying to use Jeremy's code (http://thebuildingcoder.typepad.com/blog/2013/09/creating-an-offset-wall.html), but its not working, the walls are overlapping. Can somebody give me some help ?
Here is the code I am using:
if (el is Wall)
Wall wall = el as Wall;
Autodesk.Revit.DB.LocationCurve cv =
el.Location as Autodesk.Revit.DB.LocationCurve;
using (Transaction t = new Transaction(doc, "bnps"))
t.Start();
Wall wall1 = Wall.Create(doc, cv.Curve, wall.LevelId, false);
Parameter param = wall1.get_Parameter(BuiltInParameter.WALL_KEY_REF_PARAM);
param.Set(3);
t.Commit();
Thanks in advance.
2 REPLIES 2
Dear Bruno Silva,
If you want to create an offset, please use Transform.
Your code is only to change the location reference of the wall, does not create offset.
Please see codes below:
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            Document doc = commandData.Application.ActiveUIDocument.Document;
            Reference r = commandData.Application.ActiveUIDocument.Selection.PickObject(Autodesk.Revit.UI.Selection.ObjectType.Element, "please select wall");
            Element el = doc.GetElement(r.ElementId);
            if (el is Wall)
                Autodesk.Revit.DB.LocationCurve cv = el.Location as Autodesk.Revit.DB.LocationCurve;
                    t.Start();
                    //create location of new wall, use Transform
                    Curve newlocation = cv.Curve.CreateTransformed(Transform.CreateTranslation(wall.Orientation * 50));
                    Wall wall1 = Wall.Create(doc, newlocation, wall.LevelId, false);
                    t.Commit();
            return Result.Succeeded;
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
Thank you very much, JimJia!!
Forma Design Contest
Rail Community
