- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I am trying to create a foundation slab according to existing room boundaries and I'm getting some wierd results.
If you look at the attached document I have included a macro for this:
Applying it to room 1 works fine
Applying to room 2 gets a funky shape
Applying to room 3 throws an error
I have included a commented out line that draws model lines and used it instead of creating slabs, it works fine for all rooms!
I don't know what am I doing wrong.
Here is my macro code:
public void floorByRoom()
Document doc = this.Document;
Selection sel = this.Selection;
List<ElementId> roomIdList = new List<ElementId>() ;
//Checking if there is an existing selection
if (sel.Elements.IsEmpty) // If no selection is present prompt for it
roomIdList.Clear();
RoomSelectionFilter gridSelFilter = new RoomSelectionFilter(doc);
IList<Reference> roomRefList =
sel.PickObjects(ObjectType.Element,gridSelFilter,"Select rooms");
foreach (Reference r in roomRefList){
roomIdList.Add(r.ElementId);
} else // If a selection is present filter the rooms out of it
FilteredElementCollector collector = new FilteredElementCollector(doc,sel.GetElementIds());
roomIdList=collector.OfCategory(BuiltInCategory.OST_Rooms).ToElementIds().ToList();
// Get a floor type for floor creation
FilteredElementCollector floorTypeCollector = new FilteredElementCollector(doc);
floorTypeCollector.OfClass(typeof(FloorType)).OfCategory(BuiltInCategory.OST_StructuralFoundation);
FloorType floorType = floorTypeCollector.FirstElement() as FloorType;
Transaction t = new Transaction(doc,"Floor by rooms");
t.Start();
foreach (ElementId rmId in roomIdList) {
Room rm = doc.GetElement(rmId) as Room;
Parameter rmLvlParam = rm.get_Parameter("Level");
ElementId rmLvlId = rmLvlParam.AsElementId();
ElementId viewLvlId = doc.ActiveView.GenLevel.Id;
if (rmLvlId==viewLvlId){
SpatialElementBoundaryOptions bo = new SpatialElementBoundaryOptions();
SketchPlane sp = doc.ActiveView.SketchPlane;
CurveArray roomsCurves = new CurveArray(); // Array to hold curv data collected from room boundreis
foreach (IList<Autodesk.Revit.DB.BoundarySegment> lstBs in rm.GetBoundarySegments(bo))
foreach (Autodesk.Revit.DB.BoundarySegment bs in lstBs) {
roomsCurves.Append(bs.Curve);
// Uncomment the next line to model floor (doesnt work)
//doc.Create.NewFoundationSlab(roomsCurves,floorType,doc.GetElement(viewLvlId) as Level,true,XYZ.BasisZ);
foreach (Curve c in roomsCurves) doc.Create.NewModelCurve(c,sp);
t.Commit();
}And after I solve this problem I want your advise on what is the appropreate method to apply an offset to the curves before creating the geometry, I have tried to use the Clipper library (http://www.angusj.com.......) and I have got some good results with rooms with straight boundary segments, but unfortunately this library does't seem to deal with arc segments.
Any suggestions are appreciated 🙂
Cheers,
Samer
