get value from app.config file
I am trying set up my addin to read folder name and path from app.config file.
using ConfigurationManager.AppSettings to  get the value.
this is giving me an error.(attached image)
public classAppConfig : IExternalCommand
publicResult Execute(ExternalCommandData commandData, refstring message, ElementSet elements)
UIApplication uiapp = commandData.Application;
UIDocument uidoc = uiapp.ActiveUIDocument;
Autodesk.Revit.ApplicationServices.
Application app = uiapp.Application;
Document doc = uidoc.Document;
string dir = ConfigurationManager.AppSettings["pdfOutput"];
TaskDialog.Show(dir, dir);
returnResult.Succeeded;
xmlversion="1.0"encoding="utf-8" ?>
configuration>
configSections>
sectionGroupname="userSettings"type="System.Configuration.UserSettingsGroup, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" >
sectionname="BabuRevitAPI.HCL"type="System.Configuration.ClientSettingsSection, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"allowExeDefinition="MachineToLocalUser"requirePermission="false" />
sectionname="BabuRevitAPI.Settings"type="System.Configuration.ClientSettingsSection, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"allowExeDefinition="MachineToLocalUser"requirePermission="false" />
sectionGroup>
configSections>
userSettings>
BabuRevitAPI.HCL>
settingname="pdfOutput"serializeAs="String">
value>pdf outt put folder</value>
setting>
settingname="auslocal"serializeAs="String">
value>aus local folder</value>
setting>
settingname="test"serializeAs="String">
value>I am a test</value>
setting>
BabuRevitAPI.HCL>
userSettings>
configuration>
rosalesduquej
Hello, I have resolved your issue, you can check out the blog post I did on it, if you have any more questions feel free to ask them.
http://adndevblog.typepad.com/aec/2014/09/get-value-from-appconfig-file-and-sur-la-france.html
Cheers,
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
