Creating a Drafting View
wils02
wils02
I am trying to just create a new drafting view....I have found the following series of back and forth, and it definitely helped me get somewhere.
https://forums.autodesk.com/t5/revit-api-forum/viewdrafting-create-viewfamilytypeid/td-p/5679197
HOWEVER, when I click the command in a Revit project, it just crashes and closes. From what little I understand at the moment, I think this has something to do with the "Transaction".
Is there anyone that wouldnt mind explaining, on a basic level since I am new at this, how to create a new drafting view, and where I am going wrong. I want to understand this on a fundamental level and not simply cookbook code.
The following is the code I managed to pull together
[Transaction(TransactionMode.Manual)]
    public class Command : IExternalCommand
        public Result Execute(
          ExternalCommandData commandData,
          ref string message,
          ElementSet elements)
            UIApplication uiapp = commandData.Application;
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Application app = uiapp.Application;
            Document doc = uidoc.Document;
            ViewFamilyType vd = new FilteredElementCollector(doc)
                .OfClass(typeof(ViewFamilyType))
                .Cast<ViewFamilyType>()
                .FirstOrDefault(q => q.ViewFamily == ViewFamily.Drafting);
            ViewDrafting view = ViewDrafting.Create(doc, vd.Id);
            return Result.Succeeded;
Please and thank you.
JW
jeremytammik
Dear JW,
When you create a drafting view, or any other view, for that matter, the Revit database is modified.
Any modification to the database must be performed within a transaction.
This is the very basis or Revit API programming.
If you are new to this, please begin by working through the getting started material:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
That will answer this question of yours and many more besides, and save you and others lots of hassle and complications.
Here is lots more on the topic of transactions:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.53
Good luck and have fun with the Revit API!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
wils02
Jeremy,
Thanks for the links, especially the "transactions"; its like drinking out of a fire hose, but that is how these things typically are. I will respond again if I am still confused!
JW
