Create wall
Create wall
Create wall
Since "Create wall " were been discover for several time as the link show below:
https://forums.autodesk.com/t5/revit-api-forum/creating-wall-problem/m-p/8566002
But my requirement is what if I select one or multi element => run the API =>"wall (or kind of element)have to intact contain all element been select inside"
Is it achievable?
jeremytammik
Yes, sure. Just determine the extents of all the elements of interest and create a wall around them.
If axis aligned walls are OK, you could just use the collective bounding box of all the elements.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
