Revit three dimensional section box enquiry
hi sir,
good day to autodesk, my name is liew zi tin. I have a question regarding to the revit.
i facing a problem in adjust 3d height adjust, may I know during in revit 3d view platform, if lets said i want to adjust the height in 3d section box, normally i drag the box to the level that i want. possible to have a function that we can determine the 3d level by number? possible this function to create or this function has exist in the platform?
this is the enquiry from me to autodesk, please do not hesitate to email to me if have any further information.
my email and mobile phone as below :
zitin87@gmail.com
+xxx-xxxxxxxx
thank you.
regards,
liew zi tin
jeremytammik
Dear Liew Zi Tin,
Yes, the section box information can be set programmatically.
Here are two samples demonstrating that:
https://thebuildingcoder.typepad.com/blog/2012/08/set-view-section-box-to-match-scope-box.html
https://thebuildingcoder.typepad.com/blog/2013/10/set-view-section-box-to-match-scope-box-for-revit-...
If you are new to the Revit API, you might also want to work through the Revit API getting started material before doing anything else:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#2
One important utility that you absolutely must have is the RevitLookup interactive BIM database exploration tool to view and navigate element properties and relationships:
https://github.com/jeremytammik/RevitLookup
That will enable you to navigate to the view section box and explore its properties yourself.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
