Create swept geometry along arc
I am trying to create a solid which will be a "bent cylinder", as in a tube that follows along an arc.  Here is my attempt:
public Solid CreateSolidFromArc(Document doc, Arc arc) {
    const double radius = 0.05;
    XYZ tangent = arc.ComputeDerivatives(0, true).BasisX;
    var plane = Plane.CreateByNormalAndOrigin(tangent, arc.GetEndPoint(0));
    Curve circle0 = Arc.Create(plane, radius, 0, Math.PI);
    Curve circle1 = Arc.Create(plane, radius, Math.PI, Math.PI * 2.0);
    var curveLoop = CurveLoop.Create(new List<Curve> { circle0, circle1 });
    var loops = new List<CurveLoop> { curveLoop };
    var arcCurveLoop = CurveLoop.Create(new List<Curve> {arc});
    return GeometryCreationUtilities.CreateSweptGeometry(arcCurveLoop, 0, 0, loops);
I get this exception:
Autodesk.Revit.Exceptions.InternalException: createSweptSolid failed when creating the Swept solid.
What am I doing wrong?
jeremytammik
First, I would suggest that you visualise the curves you are trying to use for debugging purposes before making the call to CreateSweptGeometry, as suggested to Debug Geometric Form Creation:
http://thebuildingcoder.typepad.com/blog/2009/07/debug-geometric-form-creation.html
Secondly, I have no sample available for CreateSweptGeometry, but maybe this one using CreateSweptBlendGeometry instead is of use as well:
http://thebuildingcoder.typepad.com/blog/2018/01/create-swept-blend-in-c.html
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Thanks for your answer!
In fact, I am creating this swept geometry for the sole purpose of visualizing a `Autodesk.Revit.DB.Arc`.  What I wanted to do is create a circle, sweep it along the arc creating a solid tube, then use the Spatial Field Manager to color the faces.  That way I would be able to see in the UI the Arc.  Is there a better way to do that (without leaving permanent data in the model)?
I don't think `CreateSweptBlendGeometry` is what I'm looking for.
In any case, I think the exception I get is a bug in the Revit API.  The error is basically saying "there's been an internal error" (which being closed-source, I can't debug...).
jeremytammik
My pleasure. Thank you for your appreciation.
It does make sense, for transient visualisation, I think.
An alternative would be to use a model curve, though non-transient.
For an internal exception, please submit a reproducible case that I can pass on to the development team for analysis:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
They should actually never leak out to the end use or add-in, I believe.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
RPTHOMAS108
return GeometryCreationUtilities.CreateSweptGeometry(arcCurveLoop, 0, arc.GetEndParameter(0), loops);
Try above
Awesome!  @RPTHOMAS108, that worked.
Thank you both!
