Reference of Face is null with Revit 2018
tubagezll
tubagezll
I try to get all faces of element, it works well with Revit 2106, but some faces have no reference with Revit 2018.
The code is something like below:
Options geOpt = new Options();
geOpt.ComputeReferences = true; // ensure we calculate the reference so that we can reserve the persistent representation string
Dictionary<Face, Solid> faceAndSolidDict1 = new Dictionary<Face, Solid>();
List<Solid> solids1 = GetElementSolids(elem1, geOpt); //a method to get element's solids
// add all faces into a list foreach (Solid solid in solids1) { foreach (Face face in solid.Faces) { faceAndSolidDict1.Add(face, solid); if (null != element1Faces) { element1Faces.Add(face); } } }
I find that Face.reference is null when Face.OrientationMatchesSurfaceOrientation is false.
tubagezll
with Revit 2016, same face has reference.
so-chong
The Face.OrientationMatchesSurfaceOrientation property identify whether the face's orientation matches the surface orientation.
If true, the reference returns a value.
If false, the reference returns null.
This property was introduced in Revit 2018, in Revit 2016 this property did not exist and that is why i think your code works in 2016 and not in 2018.
Or at least only returns(if true) faces with values in 2018.
Try use Face.GetSurface() method in 2018.
i hope this clarifies and assume what your problem was.
