Create reference plane from selected Face
zzhiweii
zzhiweii
Hi can some one help create this macro I found on Youtube?
ReferencePlaneByFace - Simply select any face and it will create a Plane. If the face in not a Planar Face then the face will be evaluated where selected and create a plane tangent to the point you picked.
https://www.youtube.com/watch?v=jgw_il1YRfg
Replies (7)
Mohamed_Arshad
HI @zzhiweii
     You need to create plane for non planar face ?
Thanks & Regards,
Mohamed Arshad K
zzhiweii
Nope I just need plane from face. Thanks!
Mohamed_Arshad
HI @zzhiweii
     My first advice is to learn Revit API from the scratch, The Below links will help you out to learn Revit API. Because this forum will help you in solving queries but it wont' provide you the complete solution.
Revit API Learning Sites
https://thebuildingcoder.typepad.com/blog/2013/04/getting-started-with-the-revit-api.html
https://www.autodesk.com/autodesk-university/class/Revit-Programming-Beginners-Easily-Access-Revit-A...
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/7I2bC1zUr4VjJ3U31uM66K.html
Kindly refer the below script for Sketch Plane creation from face.
Reference Macro Script
public void CreatePlaneFromFace()
			UIDocument uiDoc= Application.ActiveUIDocument;
			Document doc= uiDoc.Document;
			Reference faceRef = uiDoc.Selection.PickObject(ObjectType.Face);
            GeometryObject geoObj = doc.GetElement(faceRef).GetGeometryObjectFromReference(faceRef);
            if (geoObj is PlanarFace)
                PlanarFace face = (PlanarFace)geoObj;
                using (Transaction createSketchPlane = new Transaction(doc, "Create Sketch Plane"))
                    createSketchPlane.Start();
                    Plane planeGeo = Plane.CreateByNormalAndOrigin(face.FaceNormal, face.Origin);
                    SketchPlane skp = SketchPlane.Create(doc, planeGeo);
                    uiDoc.ActiveView.SketchPlane = skp;
                    doc.ActiveView.ShowActiveWorkPlane();
                    createSketchPlane.Commit();
Hope this will Helps 🙂
Thanks & Regards,
Mohamed Arshad K
zzhiweii
Hi Arshard,
I really appreciate your help but I've encountered an error message, I'm using Revit 2020
Build started.
Compiling ZW
C:\ProgramData\Autodesk\Revit\Macros\2020\Revit\AppHookup\ZW\Source\ZW\ThisApplication.cs(41,34) : Error CS1061: 'Autodesk.Revit.ApplicationServices.Application' does not contain a definition for 'ActiveUIDocument' and no extension method 'ActiveUIDocument' accepting a first argument of type 'Autodesk.Revit.ApplicationServices.Application' could be found (are you missing a using directive or an assembly reference?)
Build failed. (00:00:01.5581340)
zzhiweii
zzhiweii
Thanks much Arshad! I'm able to make it to work by editing it from
to
UIDocument uiDoc= ActiveUIDocument;
Mohamed_Arshad
HI @zzhiweii
    you have create Application Macro instead of Document. Kindly follow steps shown in below gif Image
Manage Tab --> MarcoManager ---> Choose Second Tab (It is in Project Name)
Reference GIF
Thanks & Regards,
Mohamed Arshad K
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
