Why Is A Wall Not A FamilyInstance?
I'm trying to understand how objects inserted into a Revit drawing are seen from an API point of view.
I have a simple drawing that has two structural columns inserted, and two walls (that happen to have formed a corner, but not important right now).
If I get a list of the selected elements, the two columns come out as FamilyInstance objects - Category = Structural Columns, Family = RSA-Rectangular Steel Angle-Column, Type = 200x200x24 RSA. Fits the format perfectly.
But the walls come out differently. They do appears to have a category of Walls, so far so good; but then they are not FamilyInstance - they have their own object type, Wall.
Why? Why do they not fit the same rules as other inserted objects and have a family and type? The API Wiki says they are of a system family, which makes sense - so why aren't they an instance of a [system] family type?
I just wonder why the inconsistency.
augusto.goncalves
Walls (and other types) are System Families, which are all defined by their own object.
As a reference point, if you cannot insert from a RFA file, then is not a FamilySymbol and FamilyInstance
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Fabian.OswaldS52TK
There is a trick for this:
  1. Create a project family in the model, here you can select the Wall category.
  2. Search the project browser for the project family you have just created.
  3. Right-click followed by Save...
  4. You now have a family with the Wall category.
Agrarbau - Industrie- und Gewerbebau - Behälterbau - Stahlbau - Nagelplatten - Hausbau
Oswald Fabian
