Create Options Bar
Create Options Bar
Create Options Bar
Hi
I can't find anything about how to create my own Options Bar
Is it possible to create my own Options Bar with textboxes radioboxes and ... ?
How ?
Regards Anders
Do you mean the bar that appears belowvtge ribbon for commans that need additional input from the user such as the modify->walls->attach top/base where you can select top or base? If so then yes, that would be nice but unfortunately the API doesn't support it. For this i usually display a modal dialog to the user to ask for the input before running the command logic. You could make a modeless dialog that looks similar I guess but you'll be messing around a lot to get it positioned and functioning correctly.
stever66
I'm not sure exactly what you mean by an options bar, but the API does support several types of ribbon controls.
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-1547E521-59BD-4819-A989-F5A238B9F2B3
i see split buttons, drop down buttons, radio buttons, text boxes, combo boxes, stacked panel items, and slide out items.
grubdex
Is this possible by now?
schnierer.gabor
