Create ElementType
Create ElementType
Create ElementType
I have spend some time now on trying to create a new ElementType. I understand that the only way to so is to duplicate an existing elementType. However this results in the following problem:
If you would like to create a new wall you could querry the curent default type, however this could be one of several possible System Family Types "Basiswand" "Geschichtete Wand" "Fassade". However if you need a "Basiswand" and the default is set to "Fassade" you run in a problem later on when working with the elementtype and changing its properties e.g. the CompoundStructure ...
Same goes for a floortype this could be e.g. a "Geschossdecke" or a "Bodenplatte".
The problem is that the only location where you can querry the familyNames is within the ElementTypes and this retuns the names in a lokalized form. So if I would use these names to determine the ElementType to duplicate it will fail as soon as somebody uses another language...
Any Ideas?
Revitalizer
for the WallType, check its Kind property.
WallKind.Basic is the one you need.
Language independent.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Okay I am aware of Kind, however this is not generally applicable to all ElementTypes. So it will not work for floortypes. Ever tried to create a Floor with a foundation slab type?
Both run under FloorType, however two different create functions....
Revitalizer
there is FloorType.IsFoundationSlab property, is this what you need?
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
No I need somethink where I can discinguish these things from ElementType level not for each Subclass.
Or someway how to get a language independend familyName...
so that I can now that "Fassade" ==  "Curtain Wall" == in russian == in french == in manadrin ...
Hello I solved it somehow.
However I would like to file a feature request:
an accessible language independen value referencing the SystemFamilyType of an Element.
jeremytammik
Is there an entry for that in the Revit Idea Station?
  • Yes: please vote for it
  • No: please create one
Thank you!
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
