Create New Project
Create New Project
Create New Project
when i try to create a new structural model, the system said "unknown error during access to C:\ProgramData\Autodesk\RVT2020\Templater\Italy\StructuralAnalysis-DefaultITAITA.rte"
I've already unlocked the visualization of hidden folders, but nothing has changed
jeremytammik
Are you creating the new project manually in the user interface of programmatically using the Revit API?
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
