The document does not regenerate
Hi! I change View Sheets numbers in transaction and commit all changes, but document does not regenerate. If I save and open the document again, then all changes are visible. I tried Regenerate() method of Document class, but its not helped:\
so-chong
Did you find this thread and was it useful for you?
https://forums.autodesk.com/t5/revit-api-forum/refresh-projectbrowser-after-renaming-sheetnumber/m-p...
Otherwise it's something else which i honestly do not know.
Sean_Page
You would find the answer in the post @so-chong listed, but the following three lines will get you what you need after you commit the transaction.
DockablePaneId dpId = DockablePanes.BuiltInDockablePanes.ProjectBrowser;
DockablePane dP = new DockablePane(dpId);
dP.Show();
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
