create columns types
hossam.amer666
hossam.amer666
Hello guys,
Now I have the family (M_Concrete-Rectangular-Column) and I have two lists of double that represent b and h of the column. how can I extract the unique values of the two lists and then create new family types using them?
RPTHOMAS108
Private Class ColumnType
        Inherits EqualityComparer(Of ColumnType)
        Private IntD As Integer() = New Integer(1) {}
        Public ReadOnly Property H As Integer
            Get
                Return IntD(0)
            End Get
        End Property
        Public ReadOnly Property W As Integer
            Get
                Return IntD(1)
            End Get
        End Property
        Public ReadOnly Property Name As String
            Get
                Return CStr(H) & "x" & CStr(W)
            End Get
        End Property
        Public Sub New(D1 As Integer, D2 As Integer)
            If D1 > D2 Then
                IntD = New Integer() {D1, D2}
            Else
                IntD = New Integer() {D2, D1}
        End Sub
        Public Overrides Function Equals(x As ColumnType, y As ColumnType) As Boolean
            Return x.H = y.H AndAlso x.W = y.W
        End Function
        Public Overrides Function GetHashCode(obj As ColumnType) As Integer
            Return obj.Name.GetHashCode
        End Function
    End Class
    Private Function TObj168(ByVal commandData As Autodesk.Revit.UI.ExternalCommandData,
ByRef message As String, ByVal elements As Autodesk.Revit.DB.ElementSet) As Result
        Dim UIDoc As UIDocument = commandData.Application.ActiveUIDocument
        If UIDoc Is Nothing Then Return Result.Cancelled Else
        Dim IntDoc As Document = UIDoc.Document
        Dim L1 As Double() = New Double() {100, 200, 150, 500, 400, 300, 250, 250}
        Dim L2 As Double() = New Double() {200, 200, 150, 500, 400, 300, 250, 250}
        Dim all As New List(Of ColumnType)
        For i = 0 To L1.Length - 1
            all.Add(New ColumnType(L1(i), L2(i)))
        Next
        all = all.Distinct(New ColumnType(0, 0)).ToList
        Dim FEC As New FilteredElementCollector(IntDoc)
        Dim ECF As New ElementCategoryFilter(BuiltInCategory.OST_StructuralColumns)
        Dim Els As List(Of FamilySymbol) = FEC.WherePasses(ECF).WhereElementIsElementType.Cast(Of FamilySymbol).ToList
        'Use column name here
        Dim Existing As List(Of FamilySymbol) = Els.FindAll(Function(x) x.FamilyName = "Concrete-Rectangular-Column")
        If Existing.Count = 0 Then
        Dim AlreadyExists As New List(Of ColumnType)
        Dim ToBeMade As New List(Of ColumnType)
        For i = 0 To all.Count - 1
            Dim Ix As Integer = i
            Dim J As FamilySymbol = Existing.Find(Function(x) x.Name = all(Ix).Name)
            If J Is Nothing Then
                ToBeMade.Add(all(i))
            Else
                AlreadyExists.Add(all(i))
        Next
        If ToBeMade.Count = 0 Then
        Using Tr As New Transaction(IntDoc, "Make types")
            If Tr.Start = TransactionStatus.Started Then
                For i = 0 To ToBeMade.Count - 1
                    Dim Itm = ToBeMade(i)
                    Dim Et As ElementType = Existing(0).Duplicate(Itm.Name)
                    'Use actual type parameter names
                    'Use GUIDs instead of LookupParameter where possible
                    Et.LookupParameter("h")?.Set(304.8 * Itm.H)
                    Et.LookupParameter("b")?.Set(304.8 * Itm.W)
                Next
                Tr.Commit()
        End Using
        Return Result.Succeeded
    End Function
jeremy_tammik
Nice solution. I converted it to C# and added it to The Building Coder samples for future reference:
https://github.com/jeremytammik/the_building_coder_samples/compare/2021.0.150.21...2021.0.150.22
    private class ColumnType : EqualityComparer<ColumnType>
      int[] _dim = new int[ 2 ];
      public int H
        get { return _dim[ 0 ]; }
      public int W
        get { return _dim[ 1 ]; }
      public string Name
        get { return H.ToString() + "x" + W.ToString(); }
      public ColumnType( int d1, int d2 )
        if( d1 > d2 )
          _dim = new int[] { d1, d2 };
        else
          _dim = new int[] { d2, d1 };
      public override bool Equals( ColumnType x, ColumnType y )
        return x.H == y.H && x.W == y.W;
      public override int GetHashCode( ColumnType obj )
        return obj.Name.GetHashCode();
    private Result CreateColumnTypes( Document doc )
      int[] L1 = new int[] { 100, 200, 150, 500, 400, 300, 250, 250 };
      int[] L2 = new int[] { 200, 200, 150, 500, 400, 300, 250, 250 };
      List<ColumnType> all = new List<ColumnType>();
      for( int i = 0; i < L1.Length; ++i )
        all.Add( new ColumnType( L1[ i ], L2[ i ] ) );
      all = all.Distinct( new ColumnType( 0, 0 ) ).ToList();
      FilteredElementCollector symbols
        = new FilteredElementCollector( doc )
          .WhereElementIsElementType()
          .OfCategory( BuiltInCategory.OST_StructuralColumns );
      // Column name to use
      string column_name = "Concrete-Rectangular-Column";
      IEnumerable<FamilySymbol> existing
        = symbols.Cast<FamilySymbol>()
          .Where<FamilySymbol>( x
            => x.FamilyName.Equals( column_name ) );
      if( 0 == existing.Count() )
        return Result.Cancelled;
      List<ColumnType> AlreadyExists = new List<ColumnType>();
      List<ColumnType> ToBeMade = new List<ColumnType>();
      for( int i = 0; i < all.Count ; ++i )
        FamilySymbol fs = existing.FirstOrDefault(
          x => x.Name == all[ i ].Name );
        if( fs == null )
          ToBeMade.Add( all[ i ] );
        else
          AlreadyExists.Add( all[ i ] );
      if( ToBeMade.Count == 0 )
      using( Transaction tx = new Transaction( doc ) )
        if( tx.Start( "Make types" ) == TransactionStatus.Started )
          FamilySymbol first = existing.First();
          foreach( ColumnType ct in ToBeMade )
            ElementType et = first.Duplicate( ct.Name );
            // Use actual type parameter names
            // Use GUIDs instead of LookupParameter where possible
            et.LookupParameter( "h" ).Set( 304.8 * ct.H );
            et.LookupParameter( "b" ).Set( 304.8 * ct.W );
          tx.Commit();
      return Result.Succeeded;
RPTHOMAS108
@jeremy_tammik Thanks.
Isn't it also interesting that it comes back to the notion of units. If we were comparing internal units (fractions of feet) we could not have used the integer for comparison. However since we assume it is mm and column sizes are rounded we can use easily.
So if we take the smallest measurement of length then we usually have less problems. In an imperial example if we had used inches then we can compare an integer of 6 inches rather than a double 0.5 ft. I guess if it is 6.5 inches we are stuck. However the mm is the smallest unit we generally work with (unless we are talking paint) so can represent smaller fractions of something as whole numbers.
However it is what it is.
jeremy_tammik
Interesting topic.
Intelligent rounding and unit dependent real-number fuzz.
I consider 1 mm the minimal metric unit in Revit, since it does not (or hardly) support smaller lengths.
For imperial sizes, I guess I would go for 1/16 of an inch.
Depending on what units the model happens to prefer, I would select one or the other.
