Joined Geometry: GEt common Id for joined elements
Hello, I make exporter plugin and there is one big problem which i found. When i export file in FBX, all object with joined geometry exporting as one mesh with new unique id. How i can get this id from revit api?
sameh.nabil
I usually  use the magic of delete an element then call back the transaction
this process give me all deleted items ID
then you can unjoin those items
I tried your decision and it doesn't work. I didn't see joined mesh id(
