Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Create CAD Link
Create CAD Link
pmeigneux
Create CAD Link
pmeigneux
How Create DGN Link ?
this code don't work..
if (Suffix == ".dgn")
    DGNImportOptions DGNopt = new DGNImportOptions();
    if (Doc.ActiveView != null)
        Doc.Link(NewDocPathname, DGNopt, Doc.ActiveView, out ElemId);
    else
        TaskDialog.Show(EnoviaAddPanel.ErrorText, EnoviaAddPanel.InsertNOView);
        ParentTransaction.RollBack();
        return Autodesk.Revit.UI.Result.Failed;
How Create SKP Link ?
if (Suffix == ".skp")
    SKPImportOptions SKPopt = new SKPImportOptions();
        Doc.Link(NewDocPathname, SKPopt, Doc.ActiveView);
    else
Philippe.
aricke59
The code you have shown looks like it should work.
I would check to make sure the file referred to by newDocPathname exists (perhaps try something really simple).
Of course make sure the transaction "ParentTransaction" has been started and correctly committed. Depending on the release of Revit transactions are no longer automatic and need to be fully defined.
Also make sure that "Doc" is correctly defined.
I use VB so I would also consider putting in a try/catch around the doc.link command.
pmeigneux
no , don't work..
sorry.
Philippe.
pmeigneux
This work for all link except DGN Link...
Please help me.
               Transaction ParentTransaction = new Transaction(Doc);
               ParentTransaction.Start("Create Link");
               // Create Linked
               try
                   String Suffix = Path.GetExtension(NewDocPathname).ToLower();
                   ElementId ElemId;
                   if ((Suffix != ".rvt") && (Suffix != ".ifc"))
                           if (!Doc.ActiveView.CanBePrinted)
                               TaskDialog.Show("error", "NoPrintableView");
                       else
                           TaskDialog.Show("Error"t, "InsertNOView");
                       if ((Suffix == ".dwg") || (Suffix == ".dxf"))
                           DWGImportOptions DWGopt = new DWGImportOptions();
                           if (!Doc.Link(NewDocPathname, DWGopt, Doc.ActiveView, out ElemId))
                               TaskDialog.Show("Error","ErrorInsert");
                       else if (Suffix == ".dgn")
                           DGNopt.DGNModelViewName = Path.GetFileName(NewDocPathname) + "-Model";
#if false
                           DGNopt.AutoCorrectAlmostVHLines = true;
                           DGNopt.ColorMode = ImportColorMode.Preserved;
                           DGNopt.Unit = ImportUnit.Default;
                           DGNopt.CustomScale = 1.0;
                           DGNopt.OrientToView = true;
                           DGNopt.Placement = ImportPlacement.Origin;
                           DGNopt.IgnoreUnsupportedElementWarning = false;
                           DGNopt.ThisViewOnly = false;
#endif
                           if (!Doc.Link(NewDocPathname, DGNopt, Doc.ActiveView, out ElemId)) <== Return always False
                               TaskDialog.Show("Error", "ErrorInsert");
                       else if ((Suffix == ".dwf") || (Suffix == ".dwfx"))
                           if (Doc.ActiveView.ViewType == ViewType.DrawingSheet)
                               IList<ElementId> ListView = new List<ElementId>();
                               ListView.Add(Doc.ActiveView.Id);
                               DWFImportOptions DWFopt = new DWFImportOptions(ListView);
                               Doc.Link(NewDocPathname, DWFopt);
                           else
                               TaskDialog.Show("Error", "InsertNOView");
                       else if (Suffix == ".sat")
                           SATImportOptions SATopt = new SATImportOptions();
                           Doc.Link(NewDocPathname, SATopt, Doc.ActiveView);
                       else if (Suffix == ".skp")
                   else
                       ModelPath mp = ModelPathUtils.ConvertUserVisiblePathToModelPath(NewDocPathname);
                       RevitLinkOptions rlo = new RevitLinkOptions(true);
#if !RVT_2018
                       RevitLinkLoadResult linkType;
#else
#endif
                       if (Suffix == ".ifc")
                           String NewDocRevitPathname = NewDocPathname + ".RVT";
                           Document DocIFC = revit.Application.Application.OpenIFCDocument(NewDocPathname);
                           SaveAsOptions SaveOpt = new SaveAsOptions();
                           SaveOpt.OverwriteExistingFile = true;
                           DocIFC.SaveAs(NewDocRevitPathname, SaveOpt);
                           DocIFC.Close();
#if !RVT_2018
                           RevitLinkLoadResult LoadlinkType = RevitLinkType.CreateFromIFC(Doc, NewDocPathname, NewDocRevitPathname, true, rlo);
#else
#endif
                           RevitLinkInstance instance = RevitLinkInstance.Create(Doc, LoadlinkType.ElementId);
                       else
                           linkType = RevitLinkType.Create(Doc, mp, rlo);
                           RevitLinkInstance instance = RevitLinkInstance.Create(Doc, linkType.ElementId);
                           RevitLinkType rvtType = Doc.GetElement(instance.GetTypeId()) as RevitLinkType;
                           rvtType.AttachmentType = AttachmentType.Attachment;
                   Doc.Regenerate();
                   ParentTransaction.Commit();
               catch (Autodesk.Revit.Exceptions.ArgumentNullException e)
                   TaskDialog.Show("Error", "ErrorInsert  :" + e);
               catch (Autodesk.Revit.Exceptions.ArgumentException e)
               catch (Autodesk.Revit.Exceptions.ModificationForbiddenException e)
Philippe.
