OpenIFCDocument
OpenIFCDocument
pmeigneux
OpenIFCDocument
pmeigneux
which dll contains OpenIFCDocument?
Philippe.
Accepted solutions (4)
aignatovich
Hi!
This is Autodesk.Revit.ApplicationServices.Application class method. It is located in RevitAPI.dll
pmeigneux
Hi
cannot found :
aignatovich
This method is not static, you should first of all get Application object, for example from command data:
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
var app = commandData.Application.Application;
or just document
var uiapp = commandData.Application;
var uidoc = uiapp.ActiveUIDocument;
var doc = uidoc.Document;
var app = doc.Application;
And only then call this method
jeremytammik
Dear Philippe,
Thank you for your query.
You can read this StackOverflow thread which explains how to proceed:
https://stackoverflow.com/questions/4438900/how-to-view-dll-functions
There are only a handful of Revit API .NET assemblies to explore, so it should be a matter of minutes.
I hope this helps.
Once you have answered your question, you can share the result with us, if you think it is useful.
Thank you!
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
