Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Create a newopening
2 REPLIES 2
amati_p
271 Views, 2 Replies
Create a newopening
Hi here, I want to create an opening in a wall and I want to know if you have some examples for this. I tried all things that I found on internet and on the forum and nothing worked. Is there someone to help me?
Labels (2)
2 REPLIES 2
Mohamed_Arshad
in reply to: amati_p
HI @amati_p
Kindly Refer the below code
            //Selection of Wall
            Reference refer = uiDoc.Selection.PickObject(Autodesk.Revit.UI.Selection.ObjectType.Element);
            //Get Wall
            Wall wall = doc.GetElement(refer) as Wall;
            //Diagonal Corner Points of the Rectangle
            XYZ p1 = new XYZ(500 / 304.8, 0, 500 / 304.8);
            XYZ p2 = new XYZ(1500 / 304.8, 0, 2000 / 304.8);
            //Create Opening
            using (Transaction createOpening=new Transaction(doc,"Create Opening"))
                createOpening.Start();
                doc.Create.NewOpening(wall, p1, p2);
                createOpening.Commit();
Other References
https://help.autodesk.com/view/RVT/2014/ESP/?guid=GUID-CA1FB5D9-49BE-40D6-B9AA-BFDE21B10C8D
https://www.revitapidocs.com/2021.1/06a216d4-2cf6-ec8f-df5b-10f007b70531.htm
https://spiderinnet.typepad.com/blog/2013/05/revit-net-creations-api-create-floor-and-opening-2nd-tr...
Hope this Helps 🙂
Thanks & Regards,
Mohamed Arshad K
naveen.kumar.t
Hi @amati_p ,
In addition to what @arshad99 said, would advise you to start by creating an opening in Revit in UI.
Analyse the opening element using the Revit Lookup tool and get the required points.
Use the points in the NewOpening() method.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Forma Design Contest
Rail Community
