cpython error
cpython error
mathupathy_bXL6DS
cpython error
mathupathy_bXL6DS
                 I am tested cpython command on pyrevit by using pyrevit dev hooks. Its declared above error messege. what i do
moturi.magati.george
Hi @mathupathy_bXL6DS,
I don't think your error is related to Revit API programming.
This might be a general syntax error which can be easily solved via online responses and examples https://duckduckgo.com/?q=cpython+syntax+error+invalid+syntax&t=h_&ia=web
That said, you might also try to discuss pyRevit related issues directly with its creator Ehsan in the pyRevit repository via the appropriate channels:
https://github.com/eirannejad/pyRevit#staying-updated
  Moturi George,     Developer Advocacy and Support,  ADN Open
