Count Inserted images with Revit API
I am trying to write a simple macro to count all inserted images in a project and return the count back to me, as well as the names and image types of each file.  I am relatively new to the Revit API and I am not entirely sure how to structure the script.  I've tried to run a foreach with a filteredElementCollect for  .OfClass(typeof(ImageView))  however, I do not believe that ImageView is the proper name of what I am looking for.  If anyone has any advice on this please let me know.  Thanks.
PhillipM
Try setting up your collector as this.
New FilteredElementCollector(app.ActiveUIDocument.Document).OfCategory(BuiltInCategory.OST_RasterImages)
Good luck.
Phillip
Thanks Phillip,
This is what I have compiled so far:
                public void findImports()
            Document doc = this.ActiveUIDocument.Document;
            string info = "";
            foreach (Element e in new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_RasterImages))
                BuiltInCategory.OST_RasterImages fi = e as BuiltInCategory.OST_RasterImages;
                info += fi.Name + Environment.NewLine;
            TaskDialog.Show("elements",info);
However, when I try to compile this I wind up with an error the for the line:
the error being: 'Autodesk.Revit.DB.BuiltInCategory.OST_RasterImages' is a 'field' but is used like a 'type'
Any Idea what I might want to put in its place?
PhillipM
Try This
            string info = "";
FilteredElementCollector Col = new FilteredElementCollector(app.ActiveUIDocument.Document).OfCategory(BuiltInCategory.OST_RasterImages);
            foreach (Element e in Col)
                              info += e.Name + Environment.NewLine;
Thanks! This works great, I guess I was over complicating it a bit with mine.
