Could not load file or assembly from Nuget package
I have installed a NuGet package (NumericUpDownLib) on a Revit-Addin project , it works in designer view and I also have tested the package in a separate WPF application and it works just fine. however, when I load the addin and run the command I get this error
Could not load file or assembly 'NumericUpDownLib, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
A copy of the dll is placed in the same folder as addin.dll , so why revit do not load this dependency ?
thanks for your help
RPTHOMAS108
.net will search the base directory of the current AppDomain which is where Revit.exe resides. It is not recommended to put dll's there however.
A common approach is to subscribe to AppDomain.AssemblyResolveEvent in order to specify where the system should look for an assembly when it can't find it.
Solved: Re: Missing System.ComponentModel.Annotations v4.2.0.0 - Autodesk Community - Revit Products
AppDomain.AssemblyResolve Event (System) | Microsoft Docs
NumericalUpDown is something relatively easy to create for yourself with custom WPF control, it has always been a bit annoying they don't include it and certain other controls inherent to forms. You could use a forms host in WPF and place one that way also.
