Cyrillic keynote problem. please help.
Revit keynote is not working in Mongolian or Kazakh cyrillic. I can't use  Ө  Ү  alphabets. I'm using UTF-8, windows-1251 encodes, I tried most of the encodes but still not working. Simple texts are working but I want to use Keynote in my country language just like the others. please help
jeremy_tammik
Yes, of course, I completely understand your wish.
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to system requirements, installation, product setup, optimisation, usage or other end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
