copy/paste
copy/paste
eligt7MPPZ
copy/paste
eligt7MPPZ
Is there any way to copy to cliboard ---> paste to current view  VIA the api?
I'm trying to copy dimensions from one view to another, which are basically the same but with some differences.
I don't mind having some dimension missing, but for some reason, some of the dimension cannot be COPIED, so the whole selection isn't copied. I can't find the problematic dimensions, as the error dialog shows some property line to which some dimensions are apparently attached to (if only I could find the problematic dimensions....)
I'm trying to use the api to filter out the uncopiable (don't know if that's a word) dimensions, and just copy the valid ones...
Any help would be appreciated
Thank you
jeremy_tammik
Yes, CopyElements:
https://www.revitapidocs.com/2022/7b56b5c2-3aff-f42b-ab47-de1f89a1070f.htm
For sample code, please refer to the Revit SDK and these articles:
