Macro Manager | WPFs are not working.
Organon
Advisor Advisor
Organon
I'm trying to edit a WPFs in SharpDevelop, but when I click on the main form then SD crashes. The same problem occurs in Revit 2021, 2023... Has anyone been able to solve this? Thanks.
Arquitectura | Análisis CAD & BIM | Diseño Paramétrico | Programación
BIM-METADATA | LinkedIn | YouTube
ricaun
Probably SharpDevelop does not support WPF, usually, if you need to create a more complex plugin with UI, Visual Studio 2022 is the way!
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Organon
Hi @ricaun,
It's compatible with WPFs, as the user can select from different templates.  I'll try to contact them and see what happens.
Yes, I also use VS. Thanks.
