Convert void to solid
a_minet
a_minet
Is it possible to convert a void to a solid?
I have a wall with a family of voids, I collect the voids of this family. I insert a sphere of the center of the void. I'm doing a boolean operation, but Revit doesn't want to do it. So I want to convert this void to a solid.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @a_minet ,
Is this a Revit API programming question?
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage, or end-user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us.
Also, I found out this below link  about converting void to solid in Revit UI
https://forums.autodesk.com/t5/revit-architecture-forum/converting-voids/td-p/3772212
Thank you for your cooperation and understanding.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
a_minet
I want to do it with the API.
1- Obtaining the project void families.
2- Obtaining the parts (wall) of the project.
3- Split the family of voids to get all the voids of the family instance.
3- Insertion of a family in the center of each void on the part.
4- Boolean operation to check if the distance between the void and an opening in the window is correct.
