Is that possible to convert schedules to parameters in generic annotation or convert schedules to legend using python?
I like to learn Dynamo at first place but somehow, some nodes are not updated (maybe because of the python script in the nodes?), so I give up to learn Dynamo, and looking to learn Python instead.
Solved by jeremy_tammik. Go to Solution.
So, you are addressing quite a wide variety of topics in your short question. I will just answer the first part, ok? The answer is Yes. You can access the schedule data and convert it to text, or, for instance, display it in your own custom Windows form:
https://thebuildingcoder.typepad.com/blog/2012/05/the-schedule-api-and-access-to-schedule-data.html
The text data can obviously be stored anywhere you like, e.g., in a generic annotation or legend as well.
Here are some hints for getting started in Python and Dynamo:
