ConnectorManager Connectors in Random Order and Id only available in 2016
jonathan.umscheid
Message 1 of 8
jonathan.umscheid
I found that ConnectorManager.Connectors (which is a ConnectorSet) returns its list of Connectors in a different order each time the function is called.  I'm not sure what is causing this, but I'm looking for a work-around to always get them in sequential order by Connector.Id.  In 2016, I can use Connector.Id, but in 2015, the Id property doesn't exist.  I also tried using the ConnectorSet.ForwardIterator() but it returns the connectors in random order from one call to the next as well.  One might expect the connectors to be returned by Id order, 0, 1, etc., but that's not the case.  The fact that each time the function is called, they are returned in a different order makes it difficult to use.  Anyone have a solution to this for 2014 & 2015?
Replies (7)
Message 2 of 8
Charles.Piro
what is your goal ? what addin do you want achieve ?
I can't help you for find a solution with just your post.
Smiley Wink
PIRO Charles
Developer
PIRO CIE
Linkedin
Message 3 of 8
Revitalizer
what about sorting them by Origin (XYZ) property ?
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 4 of 8
jonathan.umscheid
I have been working with conduit, duct, and pipe. I'm just trying to get a consistent list of connector points from them. It makes it difficult when the list of connectors is returned in a different order each time, so I can't rely on them being ordered from start to end or from end to start for the part.
Message 5 of 8
jonathan.umscheid
Thanks for the reply. It is a step in the right direction. I think I will have to rely on the coordinates eventually to solve this one. However, if the user modifies the points, they could be returned in a different order than from a previous call, so the order could still change. I think I'll have to rely on knowledge of the connections to adjacent parts as well to solve this.
Message 6 of 8
Charles.Piro
I understand that you want achieve. I created an addin with the same idea (for track a system), and I used the position of connector.
Good luck !!
Smiley Wink
Charles
PIRO Charles
Developer
PIRO CIE
Linkedin
Message 7 of 8
Revitalizer
conduits, ducts and pipes are line based, so you can sort the (two) connectors by comparing their origins with the location of (or the distance to) (pipe.Location as LocationCurve).Curve.GetEndPoint(0)
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 8 of 8
bogdan.scaueru
I have the same issue using the REVIT 2019.2, trying to identify the FamilyInstance of the connector using the following code:
     Private Function getEDB_Connector2Family(cLinkSystem As ElectricalSystem, cSizePanelName As stringAs Object
        Dim cPanels = New FilteredElementCollector(_DOC).ofCategory(BuiltInCategory.OST_ElectricalEquipment).WhereElementIsNotElementType().ToList()
        Dim cPanelConnectors As Object
        Dim cPanelConnector As Connector
        Dim cLinkPanel As Object
        Dim cLinkPanelName As String
        Dim cLinkConnectors As Object
        Dim cLinkConnector As Connector
        cLinkConnectors = cLinkSystem.ConnectorManager.Connectors.GetEnumerator()
        Do While cLinkConnectors.MoveNext()
            cLinkConnector = cLinkConnectors.Current()
            For Each cLinkPanel In cPanels
                cPanelConnectors = cLinkPanel.MEPModel.ConnectorManager.Connectors.GetEnumerator()
                Do While cPanelConnectors.MoveNext()
                    cPanelConnector = cPanelConnectors.Current()
                    If cLinkConnector.Id = cPanelConnector.Id Then
                        cLinkPanelName = ParameterValue(cLinkPanel, "CX_NAME")
                        If cLinkPanelName <> cSizePanelName Then
                            Return cLinkPanel
                        Else
                            Exit Do
                        End If
                    End If
                Loop
            Next
        Loop
    End Function
The cLinkSystem  contains 2 connectors. The idea is that cLinkConnector.Id returns either "1" or "0" while the cPanelConnector.Id returns a more meaningful value of "5000x"
I'm trying to identify the FamilyInstance of the circuit connector.
Kind regards,
Bogdan
