Deleting a non-shared project parameter
Hi all, Not sure if this has been answered before but I couldnt find any answer to my problem. I am trying to develop a plugin to delete parameters (shared and project) from my Revit project. Shared parameters can be deleted with no problem however I have problems when I am trying to delete a project parameter. I used the following line in order to delete the parameter: Doc.ParameterBindings.Remove(definition); Two problems I am facing here are: 1) I used a loop to delete every single parameter in the project (Shared + Project). After the loop, all the Shared parameters are gone but the project parameter still remains in Snoop Document -> Parameter Bindings. 2) I tried executing the code again to delete the project parameter and this time the project parameter is no longer in the Parameter Bindings.However, in the UI in Revit (Manage -> Project Parameters), the project parameters are still there and in the properties tab, the parameters are still there as well. Anyone here have faced/solved this problem before? Your help is greatly appreciated.
Hmm, hard to say. Did you use transactions correctly ?
Hi Alvindragon
My app delete share parameters from a class (Helper) containing shared parameters list for delete, this is my code, i hope help you
private void EliminarParametros(Document doc, Autodesk.Revit.ApplicationServices.Application app)
     foreach (KeyValuePair<string, string> elementos in Helper.Properties)
            RawEraseSharedParameterBinding(app, doc, elementos.Key, ParameterType.Text);
public static bool RawEraseSharedParameterBinding(Autodesk.Revit.ApplicationServices.Application app, Document doc, string name, ParameterType type)
  try
      BindingMap map = (new UIApplication(app)).ActiveUIDocument.Document.ParameterBindings;
      DefinitionBindingMapIterator it = map.ForwardIterator();
            it.Reset();
      Definition def = null;
      while (it.MoveNext())
        if (it.Key != null && it.Key.Name.Equals(name))// && type.Equals(it.Key.ParameterType))
                       def = it.Key;
            break;
     if (def != null)
        Transaction transaction = new Transaction(doc, "Update Revit Type");
                transaction.Start();
                map.Remove(def);
                transaction.Commit();
  catch (Exception ex)
     MessageBox.Show(ex.Message);
  return false;
public class Helper
  public static string Prefix = "eBIM";
  public static UIDocument ActiveUIDocument;
  public static UIApplication Aplication;
  public static Dictionary<string, string> Properties = new Dictionary<string, string>()
     { "Param1"," Generales"},
     { "Param2"," Generales"},
     { "Param3"," Texto"},
     { "Param4"," Texto"}
In your button or event, etc, call the method
Autodesk.Revit.ApplicationServices.Application app = (Autodesk.Revit.ApplicationServices.Application)sender;
Document doc = e.Document;
EliminarParametros (doc,app);
Good luck!
Did you ever resolve this?  I'm also having a problem deleting a project (non-shared) parameter.  Is it not possible?
FAIR59
You need to find the associated ParameterElement. If you delete that element, the projectparameter will also be removed.
string parametername = "testparameter";
IEnumerable<ParameterElement> _params = new FilteredElementCollector(doc)
		.WhereElementIsNotElementType()
		.OfClass(typeof(ParameterElement))
		.Cast<ParameterElement>();
ParameterElement projectparameter = null;
foreach(ParameterElement pElem in _params)
		if (pElem.GetDefinition().Name.Equals(parametername))
			projectparameter = pElem;
			break;
if (projectparameter==null) return;
using (Transaction t = new Transaction(doc,"remove projectparameter"))
		t.Start();
		doc.Delete(projectparameter.Id);
		t.Commit();
That works! Thanks!
