Connecting MEP Fabrications at middle in Revit API
phantbinh99
Message 1 of 9
phantbinh99
hello everyone
I'm working on a Revit API project involving MEP fabrication. I'm facing a challenge when trying to connect fabrications together at specific midpoints.
How can I connect the fabrication to the middle point (usually we connect the fabrications together through connectors using the ConnectTo method)
However the available connectors are only located at the 2 ends of the fabrication, so how can I connect to the middle point
Replies (8)
Message 2 of 9
MarryTookMyCoffe
did you try document.Create.NewTeeFitting?
do not worry it only gonna take Autodesk 5 years to fix bug
Message 3 of 9
phantbinh99
I don't think creating tee fittings is the solution, tee fittings connect 3 connectors together, while I'm looking to create a new connector in the middle to connect to the fabrication.
What do you think? Do you have any other ideas?
Message 4 of 9
MarryTookMyCoffe
you have to ask simple question, can you do it as user. There is no way to just add Connector in to menager. it would be a different story if this would be a family
Message 5 of 9
phantbinh99
Thanks for the reply, actually I can do it in manual by simply dragging and dropping the fabrication to the point I want, Revit will connect it automatically.
Message 6 of 9
MarryTookMyCoffe
ok now I know why I was confuse we were talking about FabricationPart , Ithougth we talk about ducts, my bad, I didn't read full title :D.
Unfortunately I never work on them or with them so I don't really know how they work.
I can see some method that may work in static method of FabricationPart. I thing you will need to just test every one of them and see how they work.
Good luck, god knows you will need it.
Message 7 of 9
phantbinh99
Thank you. I'll experiment with some other approaches and see if any additional assistance becomes available.
Message 8 of 9
victor.bastidas
Hi!
We're having a similar discussion here:
Can conduit connect to cable tray by using API? - Autodesk Community - Revit Products
With @jeremytammik .
It seems like the same Revit UI principle is happening, and some logic connector is being created when dragging something right up to the center of the cable tray.
Not sure if we should keep it on that post or this one, but finding a solution for this will surely help a lot!
Message 9 of 9
phantbinh99
Thank you for telling me. It seems like we are facing the same issue. It's great to see your post receiving help from a top contributor.
Let's continue the discussion in your post.
