Cannot run debug mode in Visual Studio (Revit 2025)
000853959
Message 1 of 8
000853959
Good day everone:
everytime I start debugging, it gives me Fatal Error, I tried all debug options though. Anyone have an idea of whats hapening? I can run it from VS , However, when I start debug, it crashes and pops up the following message! I use Revit 2025
Replies (7)
Message 2 of 8
moturi.magati.george
Hi @000853959,
It might be difficult for us to debug your issue. Kindly attach or send me the minimum sample for us to have a look and advice.
  Moturi George,     Developer Advocacy and Support,  ADN Open
Message 3 of 8
ricaun
Are you using Visual Studio 2022?
The error say something with NET Framework, you are building your addin with net8.0 right?
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Message 4 of 8
000853959
Correct! Iam using VS 2022 .NET 8.0 with Revit 2025. any ideas?
Message 5 of 8
000853959
Hello there:
absolutely, here is my txt file. Iam uncertain if you need more docs.🤔
Message 6 of 8
000853959
Message 7 of 8
000853959
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
namespace selectElement
[Transaction(TransactionMode.Manual)]
public class selectElement : IExternalCommand
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
// get document and ui document
UIDocument uidoc = commandData.Application.ActiveUIDocument;
Document doc = commandData.Application.ActiveUIDocument.Document;
try
// select the element
Reference reff = uidoc.Selection.PickObject(ObjectType.Element);
ElementId eleId = reff.ElementId;
//get element from element ID
Element ele = doc.GetElement(eleId);
//show element name, element category, element ID
TaskDialog.Show("Element Information", "Element Name: " + ele.Name + Environment.NewLine
+ "Element Category: " + ele.Category.Name + Environment.NewLine
+ "Element ID: " + eleId);
return Result.Succeeded;
catch (Exception e)
message = e.Message;
return Result.Failed;
Message 8 of 8
Hi @000853959
I tested your class and it seems to be working fine.
Find attached
