Compare and combine datatables
HD12310
HD12310
Hi i have to datatables - two columns in each table.
The first column in both is guid.
I need to compare the guids in these two tables.
And return one datatable witch contains the second columns from each table.
To combine data from two tables where the guid is equal.
(Note: it doesnt have to be datatables, could be string arrays or whatever really.)
This code below never returns isEq=true - anyone has some code that can do this ?
bool isEq;
foreach(DataRow r_row in dtRvtPfv.Rows)
foreach (DataColumn r_col in dtRvtPfv.Columns)
if (r_col.ColumnName == BuiltInParameter.IFC_GUID.ToString())
if (r_row[r_col] != null)
isEq = dtTeklaPfv.Select().ToList().Exists(row => row["GUID"].ToString() == r_row[r_col].ToString());
if (isEq)
TaskDialog.Show("Guid match", r_row[r_col].ToString());
jeremytammik
Dear Hd12310,
Happy New Year to you!
Sorry, I find both your question and your code hard to comprehend, so I cannot really answer it in this state.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
HD12310
Thanks for reply Jeremy.
Basically im trying to update elements based on their guid.
The elements have been exported to IFC - and sent to Tekla.
Tekla evaluates the elements and produce an status report for each element.
I have the Revit elements in one table and the tekla report in another table.
I need to copy the Tekla status from one dataTable to the other dataTable - by matching their guids like this:
DataTable1
guid                   status
287A628346     OK
387A628346     NOT_OK
DataTable2
guid                   ElementId
287A628346     Family1
387A628346     Family1
The goal is to compare and combine DataTable1 and DataTable2 - to get DataTable3
DateTable3
guid                   ElementId     status
287A628346     Family1         OK
387A628346     Family1         NOT_OK
I realize its not really a core Revit API question so i will be digging into some MSDN forums for this as well.
jeremytammik
Hi Hd12310,
Personally, I would create two generic .NET dictionaries keyed on the GUIDs.
Loop through one of the dictionaries, check whether the other dictionary has a corresponding entry.
If not, you are done. If yes, do your thing.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
HD12310
Thanks.
I ended up using the datatables directly and lopped through the rows.
Heres the working sample code if anyone is interrested.
From there on i could create a 3. datatable or just expand dtA with values from dtB.
            string guid_a = "";  //in datatable dtA
            string guid_b = "";  //in datatable dtB
            foreach(DataRow a_row in dtA.Rows)
                guid_a = (string)a_row["GUID"];
                foreach(DataRow b_row in dtB.Rows)
                    guid_b = (string)b_row["GUID"];
                    if(guid_a.Equals(guid_b))
                        //we have a match
GonçaloFeio1321
A more complicated solution, but with cleaner code would be using Linq instead or recursive loops:
http://msdn.microsoft.com/en-us/library/bb386943(v=vs.110).aspx
http://stackoverflow.com/questions/24020981/linq-query-multiple-datatables-in-dataset
HD12310
Tnx - especially the msdn link har some great examples
