How to export an image from a specific view using Revit API C# ?
Message 1 of 19
Hi
I have to export a specific view  to an Image using the API ( C# )
I have opened the models using "uiApp.Application.OpenDocumentFile..."
But I don't want to export the default view.
I have found the name of the view I want to export, I have set the Path, Pixels etc. but
how to get the right view exported ?
Anders Kaas
Replies (18)
Message 2 of 19
jeremytammik
Dear Anders,
Happy New Year to you!
Here is a description of a sample command that creates a new view to export an image from:
http://thebuildingcoder.typepad.com/blog/2013/12/setting-the-view-display-background.html
It is included in The Building Coder sample collection:
https://github.com/jeremytammik/the_building_coder_samples
That should provide a starting point, at least.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 19
Hi Jeremy
Thank you for Your answer, but I still can't get it to work !
I have this Imageexportoption but want only a view called e.g. "Level 1" in "OpenDoc" exportet as an image
I have opened a dafault template and are using the API to open others models but it is only the current view that are exportet
var BilledeExportOptions = new ImageExportOptions
ZoomType = ZoomFitType.FitToPage,
PixelSize = 2024,
FilePath = DistFolder + @"\Images\" + CSVTxt[ActRow][3].ToString(),
FitDirection = FitDirectionType.Horizontal,
HLRandWFViewsFileType = ImageFileType.JPEGLossless,
ImageResolution = ImageResolution.DPI_600,
OpenDoc.ExportImage(BilledeExportOptions);
Anders
Message 4 of 19
jeremytammik
Dear Anders,
It sounds to me as if you are answering your own question.
You say "the current view is exported".
Ok, in that case, how about making the view that you wish to export current before launching the process?
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 5 of 19
Hi
🙂  But it is the current view in the file I have opened before I run the code whitch opens an other model with the view I want to export, And I know I want to export several views in models in the future, if they have the right name, right values in specifics parameters etc.
Can't I specifie the view to be exportet ?
Anders
Message 6 of 19
jeremytammik
Dear Anders,
Have you RTFM?
Have you tested the ImageExportOptions.ViewName property?
Oh no, I see that "This field is used only to save an image to a project as a new view."
Reading further, though, I immediately discover the ImageExportOptions.SetViewsAndSheets method: "Sets a list of views and sheets to be exported. Used only when ExportRange is SetOfViews."
You should try reading as well:
https://en.wikipedia.org/wiki/Reading_(process)
The Revit API help documentation is in RevitAPI.chm that is part of the Revit SDK.
Have you installed that and do you keep it handy as a desktop shortcut or something?
If not, please do!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 7 of 19
Thanks a lot it worked
I have added the full code maybe it can be usefull to others 🙂
IList<ElementId> ImageExportList = new List<ElementId>();
ImageExportList.Add(View.Id);
PixelSize = 1024,
FilePath = DistFolder + @"\Images\" + ImageName.ToString(),
ExportRange = ExportRange.SetOfViews,
BilledeExportOptions.SetViewsAndSheets(ImageExportList);
Anders
Message 8 of 19
I am trying to export image for an ExternalApplication and it does not work. Here is the error I get "a managed exception was thrown by Revit or by one of its external applications". What does that mean? Is it not allowed to call ExportImage from an external Application?
Here is my code
                var uidoc = uiapp.ActiveUIDocument;
                var doc = uidoc.Document;
                var ieo = new ImageExportOptions
                    ZoomType = ZoomFitType.Zoom,
                    PixelSize = 512,
                    FilePath = @"c:\temp\images\",
                    HLRandWFViewsFileType = ImageFileType.PNG,
                    ImageResolution = ImageResolution.DPI_72,
                ElementCategoryFilter filter = new ElementCategoryFilter(BuiltInCategory.OST_Views);
                FilteredElementCollector views = new FilteredElementCollector(doc);
                views.WherePasses(filter).WhereElementIsNotElementType().ToElements();
                IList<ElementId> ImageExportList = null;
                foreach (View view in views)
                    if (view.ViewType == ViewType.FloorPlan)
                        try
                            ImageExportList.Add(view.Id);
                            ieo.SetViewsAndSheets(ImageExportList);
                            doc.ExportImage(ieo);
                        catch (Exception ex)
                            System.IO.File.WriteAllText(@"C:\Temp\Errors.txt", view.Name + " " + ex.Message);
Message 9 of 19
jeremytammik
No, you are not per se allowed to make any Revit API calls whatsoever from an external application, or anywhere else either, for that matter, except from within a valid Revit API context.
It sounds to me as if you are not within a valid Revit API context when your code above is executed.
Please read the detailed description of what a valid Revit API context is and how to obtain it here:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.28
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
Message 10 of 19
Revitalizer
may it be that at least one view is not valid for export, e.g. view.IsTemplate ?
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 11 of 19
Revitalizer
there is also a view.CanBePrinted property that may be checked before exporting or printing.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 12 of 19
Sorry I meant I am calling it from a class that implements IExternalApplication instead of a class that implements IExternalCommand. This is a revit addin so it should still have a valid revit api context
Sent from my iPhone
Message 13 of 19
jeremytammik
No, an external application does not automatically provide a valid Reivt API context.
Nothing in the universe provides a valid Reivt API context at all times.
A valid Reivt API context only exists temporarily within callback functions called from Revit, i.e. officially registered Revit event handlers, such as an external command Execute method or an external application ApplicationInitialized event handler.
I hop this clarifies.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 14 of 19
Hello!  Sorry if this is resurrecting an old thread, but I'm trying to generate a basic thumbnail of a view via the API using your code, and all I'm getting is a white rectangle.  It's of the correct size, so obviously some of my options are going through, but for some reason no data.  Is this a known thing?
Thanks.
-= Chris
Message 15 of 19
That happened to me if the Graphic display option had the Stype set to hidden lines. Change that to wireframe and then it will work like a charm
Sahana Pindikuri
Associate, Tech Solutions | Enstoa
Direct: +1 (212) 913 0870 x 133
Mobile: +1 (269) 599 5607
Enstoa launches Strategy & Consulting Business Unit
Message 16 of 19
Thanks for the quick reply, Sahana!
I tried as you suggested, and sadly, that did not resolve my issue.  I also tried setting the background color to green and it's still writing out just a blank white rectangle jpeg.  Also oddly, it's always writing out a jpg file, even if I tell it to write out a png file by setting HLRandWFViewsFileType to ImageFileType.PNG.
Message 17 of 19
FaustoMendezcom
Replace HLRandWFViewsFileType = ImageFileType.JPEGLossless,
With
HLRandWFViewsFileType = ImageFileType.PNG;
for PNG
here is a code snippet that you can use on macros it will save the image as PNG on your Desktop.
	UIDocument uidoc = this.ActiveUIDocument;
    Document doc = uidoc.Document;
    Autodesk.Revit.DB.View view = doc.ActiveView;
                Transaction tx3 = new Transaction(doc, "apply Filter");
                tx3.Start();
                ImageExportOptions img = new ImageExportOptions();
                img.ZoomType= ZoomFitType.FitToPage;
                img.PixelSize = 32;
                img.ImageResolution = ImageResolution.DPI_600;
                img.FitDirection = FitDirectionType.Horizontal;
                img.ExportRange = ExportRange.CurrentView;
                 img.HLRandWFViewsFileType = ImageFileType.PNG;
                 string DEsktoppath = Environment.GetFolderPath(Environment.SpecialFolder.Desktop);
                img.FilePath = DEsktoppath +@"\"+ view.Name;
                    img.ShadowViewsFileType = ImageFileType.PNG;
                doc.ExportImage(img);
                tx3.Commit();
Hope it helps 🙂
www.faustomendez.com
Message 18 of 19
jeremytammik
I confirm that this works perfectly well.
I implemented and tested it in The Building Coder samples release 2017.0.127.7:
https://github.com/jeremytammik/the_building_coder_samples/releases/tag/2017.0.127.7
https://github.com/jeremytammik/the_building_coder_samples/blob/master/BuildingCoder/BuildingCoder/C...
/// <summary>
/// New code as described in Revit API discussion
/// forum thread on how to export an image from a
/// specific view using Revit API C#,
/// http://forums.autodesk.com/t5/revit-api/how-to-export-an-image-from-a-specific-view-using-revit-api-c/m-p/6424418
/// </summary>
static Result ExportToImage3( Document doc )
  Result r = Result.Failed;
  usingTransaction tx = new Transaction( doc ) )
    tx.Start( "Export Image" );
    string desktop_path = Environment.GetFolderPath(
      Environment.SpecialFolder.Desktop );
    string filepath = Path.Combine( desktop_path,
      view.Name );
    img.ZoomType = ZoomFitType.FitToPage;
    img.PixelSize = 32;
    img.FilePath = filepath;
    doc.ExportImage( img );
    tx.RollBack();
    filepath = Path.ChangeExtension(
      filepath, "png" );
    Process.Start( filepath );
    r = Result.Succeeded;
  return r;
Is the transaction really needed at all?
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 19 of 19
I got it working.  Not sure what the problem was, but I solved it by moving the method out of the larger (threaded) routine it was a part of up to the parent method.  Thanks for all the advice and code snippets!  I think I ended up using and modifying bits of all of them.
